Old 07-30-2016, 07:24 PM   #1
DGM-BRZ
DGM-BRZ's Avatar
Drives: 2017 CWP STi
Question about custom tuning and tuning
I've got a few questions for tuners out there.
Is it true that torque can be tuned? For example, tuning the car so that it pisses gas at low RPMS to increase torque?
I'm looking to buy a header. I can't find any UEL headers for sale in my area so I'm resorted to looking at EL headers.
The twins are notorious for the low end torque and power and apparently UEL headers help with that a lot. I hear EL headers help peak powers more than low end torque. (I want low-end torque/hp)
So, is it true that I could buy an EL header and get a custom tune so my low-end torque is higher and maybe sacrifice peak power?
DGM-BRZ is offline   Reply With Quote
Old 07-30-2016, 10:01 PM   #2
steve99
Not rearly, the torque dip is a lot to do with the valve timing and the header design.
tuner adjust parameters to get the best resultsxthey can but its also a lot to do with the header
you can buy a gruppe s uel header pretty cheap and they are good quality
and their are plenty of oft the shelf tunes for those headers
if you want the best of both el and uel headers then your going to need to spend up on an ACE header and a custom tune probably cost you about tripple the price
Old 07-30-2016, 11:11 PM   #3
DGM-BRZ
DGM-BRZ's Avatar
Sadly, the gruppe uel is on worldwide backorder according to ft86motorsports.
Im too impatient for that..
Old 07-31-2016, 04:01 AM   #4
steve99
you could buy the dearer tomei version or maybe the openflash 2 header
www.openflashtablet.com
you can buy the header alone or the header and tune device\tunes included for about $1000
http://www.openflashtablet.com/shop/oftofh2-combo/
then you can flash your own tunes for petrol 91\93 and e85
Old 07-31-2016, 02:57 PM   #5
shr133
shr133's Avatar
Drives: 2013 FRS
Yes you can change your tune to change the power curve...
I just put on a P & L long tube header no cat and had to change my cam and fuel maps...
I have an auto and need to maintain low end torque....
My car runs great with the EL long tube, better than I thought and I can add the cat for better torque but I don't think I need it...
But you can get a header from FT86 speed factory...... They have online sales........
and their header sounds great.......
I don't think anyone has done a side buy side test of headers yet....
shr133 is offline   Reply With Quote
Old 08-01-2016, 10:51 AM   #6
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
“Tuning” doesn’t work that way…
A scientifically & mechanically correct performance calibration won’t leave very much room to “move” power around. If your ignition timing is ideal (MBT), and AFR’s are optimum (LBT) throughout the rev range, then you’re making as much power as safely possible throughout the rev range. Just throwing more fuel at an engine won’t increase power, in most cases you’ll actually lose a lot of power. Pump gas has a very narrow and unforgiving “sweet spot” meaning: LBT may be 12.3:1 to 12.6:1 – anything richer or leaner will lose power.
Alcohols are a lot more forgiving and easier to tune in this respect. You can have liquid methanol coming out of your exhaust before power drops off from being too rich (but you won’t make more power from being that rich).
scmil95eg is offline   Reply With Quote
Old 08-01-2016, 12:37 PM   #7
FRS Justin
Drives: 2013 Asphalt FRS
PPE UEL with merge collector
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Custom Tuning DGM-BRZ Software Tuning 28 06-30-2016 05:02 PM
Delicious Tuning is the way to go for a custom tune. Canivideo User/Vendor/Sponsor Reviews, Feedback, Comments 5 01-13-2015 04:47 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
