Old 08-02-2016, 07:04 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
AD08 or RE71R
I have had amazing performance out of the AD08. My question is has anyone ran the Bridgestone POTENZA RE-71R? Any opinions?? Ordering one or the other in the morning.
tofurun is offline   Reply With Quote
Old 08-02-2016, 07:31 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
i have not personally ran them, but everything I've read from others show that the RE71 is a damn grippy tire, but the treadwear isn't quite consistent with what would be expected from a 200TW tire. Sounds like they wear down a bit on the fast side.
TylerLieberman is offline   Reply With Quote
Old 08-02-2016, 07:33 PM   #3
tofurun
tofurun's Avatar
Thank you. The only difference I see is the wet grip isnt as good from them as the AD08. But wet grip/noise/and a speedy wear is fine as long as they grip hard as possible lol.
Old 08-02-2016, 09:16 PM   #4
86Tony
Drives: 2015 AOZORA EDITION
get 71r trust
86Tony is offline   Reply With Quote
Old 08-02-2016, 11:03 PM   #5
tofurun
tofurun's Avatar
Originally Posted by 86Tony View Post
get 71r trust
English lol?
Old 08-03-2016, 09:59 AM   #6
IPGJames
Drives: ...Cars...
my first set of tires on my BRZ for the track were RE71r...very impressive tire...yes...they wear quickly but if you want a solid "200tw" tire the RE71r seems to continue to be the king.....my first set lasted basically 11 track days before they were toast (very little street miles during that time)
I then switched to NT01s....I am not sure if it is the tire or the confidence but the NT01s were between 1-3 seconds a lap quicker than the RE71r depending on the track I was at....but with a cost of life span...realistically I would get 6-7 full days out of NT01s before they were about done....i honestly think they are a quicker tire for me but they do not last as long....
i have just now mounted up another new set of RE71r tires to run starting this weekend as i wanted to have a more all in 1 tire that i could drive to the track, run and drive back if I choose...after running NT01s for the last 12 track days I have done I am curious to see how the RE71r will feel
IPGJames is offline   Reply With Quote
Old 08-03-2016, 10:31 AM   #7
tofurun
tofurun's Avatar
Ordered the 71s today
Old 08-03-2016, 02:59 PM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I run RE71R's on my Forester XT and they are genuinely incredible.
Wear is, indeed, fast. If you can live with having a backup set of wheels and tires to bring with you, or don't rack up a ton of miles, they are a wonderful choice.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-03-2016, 03:36 PM   #9
Icecreamtruk
Drives: Track preped NA FRS
When you say you had 6-7 days in the nittos, how many hours per day did you have on track? And were they done in by heat cycling or wearing down?
Old 08-03-2016, 04:18 PM   #10
IPGJames
Drives: ...Cars...
a typical track day for me is 4-5 20-25 minute sessions
done by wearing out...down to cords...they never got slower as they wore
the right rear on my car seems to get very little wear on the tracks i go to...i can get 40-45 heat cycles on that corner ....the other 3 corners i can get about 30 heat cycles before they are worn down
Old 08-03-2016, 05:46 PM   #11
MrsJames
So. Many. High-heels.
Drives: 2016 Halo FR-S
They are a great tire. However, most spec 86 race series do NOT allow them at all (as noted) because their grip is not exactly inline with a 200 tread wear tire - hence the earned name "cheater tires."
If your car is bone stock, this tire will be slower around a track than a slightly less sticky tire as you will have a hard time slipping where you need to in order to carry maximum speed.
So, to be clear, I am not advocating for you to supercharge tomorrow incase your significant other reads this statement... but if you were supercharged or something like that, you would have one hell of a time.
Counterpoint to this is that I had a blast in a friends seriously tuned up naturally aspirated BRZ running NT01's...
I would have bought the RE71r's myself but I want to play in the stock class for Spec86 series!
MrsJames is offline   Reply With Quote
Old 08-03-2016, 06:06 PM   #12
tofurun
tofurun's Avatar
Going full exhaust and tune next month so hoping to make the extra power I'm going to need. I know the ad08 on the Miata if u dropped the clutch it would stall. Rlly hard to get any slip at all. So I understand what you are saying. I was going to wait till next month to get them anyways but I picked up a nail this week on the sidewall and couldn't be patched
Old 08-04-2016, 11:26 AM   #13
IPGJames
Drives: ...Cars...
my car is bone stock power wise and I have never had any complaints on either the RE71r or NT01 on the car...the car works just fine on them.
RE71R abnormal wear? BR-ZED Tracking / Autocross / HPDE / Drifting 13 03-23-2016 12:17 AM
FS: 17x9 Enkei RPF1 & 245/40 Potenza RE71R ksconekiller Wheels and Tires 11 01-04-2016 02:22 PM
Enkei RPF1 17x9 +45 with 245/40 Potenza RE71R ksconekiller Wheels and Tires 1 10-27-2015 11:23 PM
Bridgestone Potenza RE71R Stagger funcheung Canada Classifieds 0 08-19-2015 05:43 PM
Yoko AD08 opinions? Captain Snooze Tracking / Autocross / HPDE / Drifting 7 02-06-2013 09:50 AM
