Old 07-07-2012, 10:06 PM   #1
White64Goat
Rear End Ratio
Was reading the service manual and was surprised to find that the rear end ratio is a 4.10 and that with a manual transmission 1.0 to 1.0 ratio is in 5th gear and is 1.0 to 1.0 in 4th gear with the automatic transmission.
Also wondered if anyone knows what the wheel lug bolt pattern is? 5x100mm possibly?
White64Goat is offline
Old 07-07-2012, 10:08 PM   #2
OrbitalEllipses
Drives: Attitude
I'm glad you found it surprising; I don't care what surprised you. 4.1 is better than the 3.7 the automatic gets in Japan.
Yes. This has been covered ad-nauseum. In case you want to know, hub bore is 56.1mm.
OrbitalEllipses is offline
Old 07-07-2012, 10:44 PM   #3
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Damn. Orbital is pissed.... Hahahaha.
DIE1000DEATHS is offline
Old 07-07-2012, 11:07 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
FT withdrawal before even getting the first dose is a real b****.
Draco-REX is offline
Old 07-07-2012, 11:07 PM   #5
OrbitalEllipses
Drives: Attitude
Nope! This is normal, let's not go to pissed. We need some stickies with information pertaining to the car so people aren't asking the same stuff over and over and over.
Old 07-07-2012, 11:32 PM   #6
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Agreed... A FAQ sticky with links to the break in thread, the wheel sizing and spacing, tire size, gear ratios, etc. etc. etc.
Chewie4299 is offline
Old 07-08-2012, 12:37 AM   #7
dabocx
dabocx's Avatar
Drives: Scion FRS
The problem is will people actually read it -_-
dabocx is offline
Official BRZ MPG Numbers. Big Gear Ratio Differences? aLiskov Engine, Exhaust, Transmission 56 01-16-2021 05:41 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 11:44 AM
FR-S Gear Ratio Comparison SpeedR Engine, Exhaust, Transmission 36 02-25-2016 10:34 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 03:23 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
