Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-08-2012, 03:31 AM   #1
leej
Drives: 86 GTS
Will US spec lowering springs for the FR-S fit on our 86 in Aus?
as per title...
I put this topic in the suspension thread (Difference in Eibach prokit springs??) but no one seems to know..
Basically I want to purchase some Eibach Pro-Kits for my 86 and I've been browsing on some US websites for some. Then i was told after contacting Eibach in australia that there might be a difference in Eibach pro kits from the US market compared to the world market (which is coming to AUS).. what i want to know is would the ProKits from the US market fit on our 86 aus spec??
leej is offline   Reply With Quote
Old 07-08-2012, 03:41 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
the difference might only be the spring rates
buy the size will definitely be the same. so yes it will fit
86_ZN6 is offline   Reply With Quote
Old 07-08-2012, 03:42 AM   #3
JiB
JiB's Avatar
Drives: GT86
an inch drop isnt much though
JiB is offline   Reply With Quote
Old 07-08-2012, 03:44 AM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
you might wana try sportlines if you want to go lower
but anything lower than 1.5 will be bad for the stock shocks
Old 07-08-2012, 04:22 AM   #5
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
And given that these cars have only about 130mm ground clearance stock, and the minimum legal limit is 100mm in Australia (well QLD at least) you might wanna keep that in mind if going more than 1in (25mm).
Nafe is offline   Reply With Quote
Old 07-08-2012, 04:54 AM   #6
leej
Drives: 86 GTS
a 1" drop is enough imo taking in some consideration of the conditions
yes, sportlines will look better and it gives a bigger drop of 1.4" but it'll ruin ur oem struts quicker, plus taking in the fact of the horror road surfaces here in sydney, it'll blow out the oem struts even quicker... to pro-long the life of oem struts im sticking with pro-kits. thoughts anyone?
Old 07-08-2012, 04:55 AM   #7
JiB
JiB's Avatar
Drives: GT86
as much as I like the look, I won't be lowering anyway,
Old 07-08-2012, 05:24 AM   #8
leej
Drives: 86 GTS
here is a before and after of DarrenDriven's car with and without Eibach Prokits
http://www.ft86club.com/forums/showp...9&postcount=16
its not much of a drop but it sure looks better!
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 15 07-22-2012 12:46 AM
TEIN S-Tech Lowering Springs zex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-18-2012 08:50 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 12:04 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-11-2012 12:36 AM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 03:05 PM
