Old 07-08-2012, 04:04 PM   #1
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Question Alignment Specs?
anyone have the factory alignment specs for both FRS and BRZ?
most alignment shop still doesn't have them on their alignment rack
not even toyota!
care to share?
thanks!
86_ZN6 is offline   Reply With Quote
Old 07-08-2012, 05:31 PM   #2
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Front:
Camber: 0 +/- 45' (0 +/- 0.75°) (Right/Left Difference: 0°45' (0.75°) or less)
Caster (Reference): 5°54' (5.90°)
Steering Axis Inclination (Reference): 15°31' (15.52°)
Toe (Each Wheel): 0°00' +/- 0°11' (0.00° +/- 0.19°)
Toe (Total): 0 +/- 3.0 mm (0 +/- 0.1181 in.)
Rear:
Camber: -1°12' +/- 45' (-1.20° +/- 0.75°) (Right/Left Difference: 45' (0.75°) or less)
Toe (Each Wheel): C + D: 0°10' +/- 0°15' (0.16° +/- 0.24°)
Toe (Total): 2.0 +/- 3.0 mm(0.0787 +/- 0.1181 in.)
Hope that helps.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-08-2012, 07:09 PM   #3
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
im assuming these are the same with the BRZ right?
Old 07-08-2012, 07:39 PM   #4
Jeff Lange
Jeff Lange's Avatar
That I'm not sure of, but I know I saw the BRZ RM PDF floating around a while back, I'm sure they'd be listed in there.
Jeff
Old 07-14-2012, 08:58 AM   #5
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
thanks i ll need those this morning!
Silverdub is offline   Reply With Quote
Old 07-18-2012, 06:50 PM   #6
Norcalscionchamp
Norcalscionchamp's Avatar
Drives: Whiteout 6MT Scion FR-S
Where did you get this info... My Toyota dealer hasn't gotten the specs yet either... Just curious looks right to me
Norcalscionchamp is offline   Reply With Quote
Old 07-18-2012, 07:10 PM   #7
Jeff Lange
Jeff Lange's Avatar
Every Toyota dealer has these specs, they're in the repair manual from Toyota, which every Toyota dealer accesses through TIS.
They probably mean their alignment machine software hasn't been updated with the information yet.
Jeff
Old 07-18-2012, 09:30 PM   #8
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Anybody have any recommendation for alignment setting for cars that see occasional track days?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-18-2012, 10:28 PM   #9
mact
Drives: 13 GTI
Just go to any shop that performs alignments and have them perform a "before" reading.
mact is offline   Reply With Quote
Old 07-18-2012, 10:31 PM   #10
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
stock Suspension???
My reccomendation:
zero toe front with as much camber as you can get...(put in the factory Crash bolts) that should render you about -1 degree or so..
Rear.. .1 toe in on each side.. camber for stock is about -.5 or so
Hope that helps...My BRZ has been on the rack about 4 times since I owned it..
Bill
Scooby South is offline   Reply With Quote
Old 07-19-2012, 12:18 AM   #11
Scooby South
Conedancer
here is the Factory alignment that My BRZ came with... kinda wonky if you ask me..
Old 07-19-2012, 12:23 AM   #12
Scooby South
Conedancer
after a alignment check and adjustment..round 1... on stock suspension. the rear was adjusted to be even .1 toe in on each side..
Old 07-19-2012, 02:59 AM   #13
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
To add to Jeff_Lange's post, here are the official FR-S alignment specs:
azian_advanced is offline   Reply With Quote
Old 06-10-2013, 07:30 PM   #14
BeRZed
The shop I'm getting an alignment only has specs for the frs. Is that okay to use the frs specs on the brz?
BeRZed is offline   Reply With Quote
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 10:33 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 03:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 04:25 AM
BRZ CDN specs up at Subaru.ca! Sport-Tech CANADA 17 04-05-2012 10:12 PM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 04:58 PM
