Old 09-07-2016, 04:49 PM   #1
FRSport.com
FRSport.com's Avatar
Drives: Scion FR-S Subaru BRZ
Send a message via AIM to FRSport.com
DIF Top Hats -- Caster/Camber Adjustable, Caster Adjustable, and Coaxial Rear
We are putting the finishing touches on our own DIF top hats for the FRS/BRZ, as well as other vehicle applications to be introduced in the future.
  • Designed, manufactured, and assembled in Southern California
  • High clearance spring perch allows for maximum compression travel
  • Upper mount install kit is specific design for each coilover kit. Will include upper spring perch and coilover-specific center nut and is priced separately from the top hat
DIF 10622 - Camber/caster adjustable front upper mount, Scion FR-S/ Toyota 86 / Subaru BRZ
  • MSRP - $400.00
  • Top Hat Coaxial install kit (not pictured) MSRP - $150.00
  • 0 ~ -3 degrees camber adjustment without eccentric bolt
  • 7075 aluminum material
  • 18-8 stainless steel mounting screws
  • 303 stainless camber washers
  • FK teflon-lined bearings
  • Mounting bolt retainers allow easy top-side only mounting and caster adjustment
  • Raised bearing mounting point frees up to 0.750" of compression stroke compared to stock
DIF 10623 - Caster adjustable front upper mount, Scion FR-S/ Toyota 86 / Subaru BRZ
  • MSRP - $300.00
  • Up to 4 degrees of negative camber at static ride height with stock springs. Actual camber will vary based on your suspension ride height and adjustable lower arms.
  • Fixed mounting bolt allows caster adjustment with precision
DIF 10624 - Coaxial rear upper mount, Scion FR-S/ Toyota 86 / Subaru BRZ
  • MSRP - $300.00
  • True coaxial design that minimizes spring bind when lowering the car
  • Raised bearing mounting point frees up to 0.836" of compression stroke (1.115" at the wheel) compared to stock
For an idea of how this will look, here's the DIF top hats mounted on a set of KW V3 (for sale very soon):
Many of our staff (including the machinist of the top hats) are at SCCA Nationals this week competing. We hope to get answer(s) and more details out to everyone shortly.
Thank you.
FRSport.com is offline   Reply With Quote
Old 09-08-2016, 07:14 PM   #2
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Compatible with OEM struts and springs? (Ie. TRD) ?
Joe-G is offline   Reply With Quote
Old 09-08-2016, 07:46 PM   #3
FRSport.com
Hello,
The upper mounts do not include the suspension-specific installation kit.
We could make one for the OEM spring. However, it may not give you the suspension travel benefit you seek as the springs will be preloaded.
Old 09-08-2016, 08:22 PM   #4
FRSport.com
We've updated the original post w/ MSRP.
  • MSRP - $400.00
  • MSRP - $300.00
  • MSRP - $300.00
Old 09-08-2016, 11:09 PM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by FRSport.com View Post
Hello,
It could be a great way to lower the car on factory springs and not have to worry about losing compression travel...?
Old 09-09-2016, 12:40 AM   #6
FRSport.com
It's definitely possible. We will take this suggestion into consideration and see it can be done economically.
Thank you.
Old 09-10-2016, 07:10 PM   #7
RJasonKlein
RJasonKlein's Avatar
These look very well made and well thought out - great job!
RJasonKlein is offline   Reply With Quote
Old 09-10-2016, 08:38 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Yet another cascam plate. It will be hard to allocate significant market share vs existing offerings or due several coilovers featuring own camplates in set. I'd prefer to see someone finally making something different, eg. camber plate with rubber bushing, something where Whiteline failed with their discontinued Com C with failing bearings.
Old 09-12-2016, 03:43 PM   #9
FRSport.com
Thank you for the feedback.
The rear top hats are a coaxial design that removes spring bind issues with traditional coilover rear top hats that do double duty as a spring perch.
The fronts have more travel built in to them, but we also offer one with maximum camber and caster adjustment only, which is unique on the market.
Rubber bushings are nice, but unfortunately the entire market is sold on pillowball upper mounts as the preferred upgrade route.
Old 09-20-2016, 12:01 AM   #10
teotl
Drives: fr-s
Thanks for offering us another option.
Honestly I don't know what the previous poster is talking about.
I've been looking for top hats that allow extra compression travel and so far only you guys and Cygnus offer it.
I know KW also has their own, but they ca n not be purchased separately
teotl is offline   Reply With Quote
Old 02-03-2017, 07:53 PM   #11
FRSport.com
PM for ordering details.
Old 02-04-2017, 05:51 PM   #12
MyGT86Yas
Drives: 2017 WRB BRZ
Just got their front camber plates matching with my kw v3. Good price and the product looks very high quality (not a pro tho) and they have good customer support. Will recommend.
MyGT86Yas is offline   Reply With Quote
Old 03-23-2017, 04:47 PM   #13
FRSport.com
up
Old 03-23-2017, 04:58 PM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm not understanding the coaxial install kit.
Perhaps I just don't realize what it is or how it fits in. Could you provide a picture of it? Is it needed to install with a coilover like the KW V1's?
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
WTB camber/caster plate scionfr_s Want-To-Buy Requests 3 02-28-2016 05:31 PM
WTB: 60mm Caster/Camber Front Top Hats sw22 Want-To-Buy Requests 0 02-10-2016 05:02 PM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 09:09 PM
WTB: caster/camber plates - Or rear suspension alignment pieces STS-V Want-To-Buy Requests 0 06-27-2014 10:24 AM
Adjust camber/caster from top or bottom? diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-22-2014 05:03 PM
