Old 09-09-2016, 03:52 PM   #1
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
Wire Valenti Reverse Light to Stock Tail Lights
Whats up guys.
Im trying to wire my valenti diffuser reverse light to my existing taillights so I could see the brake light. Right now it just plugs into the existing harness showing the reverse light.
Coming of the valenti light is a plug, red wire and a blue wire. My taillights aren't coming in the mail for 2 weeks so I cant tell what colors to splice the red and blue wire into. In the video they wire it to valenti tail lights only. I just want to enable the brake light as well while having the stock tail lights.
Here are 2 images showing what I see in the video vs what I have in real life. Thanks
fizzymike is offline   Reply With Quote
Old 09-09-2016, 06:51 PM   #2
fizzymike
fizzymike's Avatar
bump
Old 09-09-2016, 08:13 PM   #3
humfrz
Originally Posted by fizzymike View Post
bump
Well, grasshopper () one wire goes to the positive lead (where the electrons are coming from) the other wire goes to ground.
Sometimes, with lights, it doesn't make any difference.
So, use an amp meter to find the positive lead that is hot when you want the lights to go ON, and hook one wire to it. Hook the other one to something that is grounded.
Oh, just keep trying stuff ...... soon you will see the light .....
Bubba says you can find a hot wire with a test light or scratch the suspect hot wire on something that is grounded ...... and look for the sparks. Bubba also replaces a lot of fuses with his technique ......
humfrz
Old 09-09-2016, 09:20 PM   #4
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
In a DC system, black is generally a negative (grounded) conductor. That being said automotive wiring harnesses can be whatever the manufacturer decided to do. With a red and blue wire, I would venture to guess the red is + and the blue is -. Many European and Asian power cords use blue as a neutral, or grounded, conductor. Like Hum said, though, to be safe get a cheap multimeter and find the + wire first before you try splicing. LEDs don't generally take kindly to being connected backward. They are diodes (Light Emitting Diode) and definitely have a + and - connection. You can easily damage a LED by reversing polarity of the power connection.
"No matter where you go, there you are" - Buckaroo Banzai
wireman957 is offline   Reply With Quote
Old 09-09-2016, 09:39 PM   #5
humfrz
Well, I'll be darned, I didn't know that....
I don't have any LED lights on my car ....... none that work that is .....
Yep, I'm adding ol @wireman957 to my staff of consultants ......
humfrz
Old 09-10-2016, 04:57 PM   #6
fizzymike
fizzymike's Avatar
Thank you, I didnt wanna just wire it to light up but wire it to the existing tail lights so it only comes on when running lights are on
reverse light, valenti
Toms tail lights with Valenti bumper reverse light? Phaedrus29 Cosmetic Modification (Interior/Exterior/Lighting) 41 02-16-2016 05:45 AM
Crystal eye tail lights with Valenti reverse light? unsurety Cosmetic Modification (Interior/Exterior/Lighting) 2 08-21-2015 10:36 AM
WTB: Valenti Tail Lights & Reverse Bar Combo TONY_BRZ Exterior Parts (Aero, Lighting, Etc.) 0 11-24-2014 10:18 AM
FS: Valenti LED Tail lights + LED Reverse Lamps donutfilling Exterior Parts (Aero, Lighting, Etc.) 6 03-27-2014 02:52 AM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 01:14 PM
