NW Region Moderator
Drives: FR-S No More
Suspension Review: Eibach Pro-Kit Lowering Springs
This topic is linked from:
BRZ/FR-S Suspension Options List (Springs and Coilovers) ![]() Product: Eibach Pro-Kit Lowering Springs Front: claimed 1.0" vs actual 7/8" (rate: 3.6kg/mm) Rear: claimed 1.0" vs actual 7/8" (rate: 4.9kg/mm) Part No: 8210.5.140 MSRP: $359 Manufacturer Link Lowering Spring Installation DIY I have had the Eibach Pro-Kit on my FR-S for about a week now, with over 200 miles of spirited driving on the street and in the mountains. I am extremely happy with this product as it simply improves the driver's experience with a slightly stronger connection to the road without being overly harsh. The drop is advertised as a 1.0" front and rear, although my 2013 FR-S was only lowered 7/8" evenly at all four corners. That is close to an inch, but with the car riding so high to start off with I wish that the error would have been in the other direction. The new look simply removes the unsightly wheel gap that plagues the Scion. The front spring rate is increased by 56% (3.6kg/mm vs 2.7kg/mm stock) and the rear by 29% (4.9kg/mm vs 3.8kg/mm stock) and although this sounds a little extreme, some coilover kits have four times the stiffness of the stock springs. These springs aren't harsh. Road feel is improved, but I don't cringe when I see a ripple, pothole or driveway. The car has a tendency to bounce just a bit more under aggressive driving on extremely rough surfaces, though, and I would definitely recommend upgrading the dampers (shocks) as a complimentary modification if you plan to take driving seriously. Around town you could easily live with the stock shocks (until they die, possibly) I would recommend these springs for the BRZ/FR-S owner who simply wants to remove the 4WD look of the car without resorting to any extreme measures. The Eibach brand is an industry staple and customer satisfaction is high. This is a safe bet at a good price. ![]() Front Spring comparison with stock on top and Eibach Pro-Kit on bottom ![]() Rear spring comparison with Eibach Pro-Kit on top and stock on bottom ![]() ![]() ![]()
Drives: 2015 Mustang GT (on order)
looks nice! I don't ever upgrade springs without upgrading shocks though.
NW Region Moderator
Well, I have coilovers on the way but I simply couldn't look at the car any longer with the nosebleed altitude.
Drives: Volkswagen Golf GTI
One thing I don't understand.
How do they measure the spring rates on a progressive coil design? Did they measure the rate of the first, middle or last section of compression?? |
Boosted
Drives: Sideways
Good review. but at the looks of that, I'm going to need at least a 2" drop. I will have nothing less than HELLA FLUSH.
Boosted
Drives: Sideways
These: http://www.ebay.com/itm/Tein-Tech-Sp...449c6a&vxp=mtr
Look like they could give a bit more of a drop. I'm curious as to what Megan Racing will provide since they always seem to give a lower drop than others. |
head of infinite swagger
Drives: 2013 FR-S 6MT
damn that looks good but not enough drop for me either, i was hoping i could avoid coilovers but maybe not....
NW Region Moderator
The Eibach Sportline springs are a 1.4" drop all around, those are another good alternative to coilovers if you want to save $$$.
Drives: 1991 MR2 turbo, 2013 Scion FRS
thanks for the review! did you by chance take a before and after picture of the wheel gap from the fender to the wheel at close range? id love to see those as well if you did.
#10 |
El Presidente
Drives: it like I stole it!
Nice post. The car looks great!
#11 |
NW Region Moderator
Not up close, I didn't. Shoot.
#12 |
Boosted
Drives: Sideways
Seems like 19 inch wheels and the lowest drop springs might achieve a decent flush status. But 18 inch wheels and smaller will probably need coilovers.
#13 |
its all good. all you really have to do is get another board member with the same color car to take the stock height photo, then you yourself take the photo of your car as it is now. Overall, looks really good, what shocks are you eventually switching to once the stockies go?
#14 |
NW Region Moderator
I have coilovers on the way, these springs are just temporary until the coilovers show.
| RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! | Racecomp Engineering | Brakes, Suspension, Chassis | 141 | 10-07-2012 09:12 PM |
| Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 15 | 07-22-2012 12:46 AM |
| Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 4 | 07-06-2012 12:04 PM |
| Anyone running Eibach lowering springs? | Bahraini86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-01-2012 03:05 PM |
