Drives: 2014 Scion FRS
WRX rear sway bar: good front sway bar combo?
I've been doing some research into front/rear sway bar combos. I haven't seen much info on a good front sway bar option with the WRX rear in autox terms. I probably won't actually being autoxing my car, but I am curious about an aftermarket setup that would increase the overall performance/grip of the car and reduce some body roll. I'm not really looking for something that would increase oversteer, and I don't want something too intense obviously. It looks like the WRX rear is a decent (*inexpensive*) option, seeing as it is 2mm thicker than stock, at 16mm.
I'm currently lowered on basic coilovers, supposedly with spring rates at 6k front/7k rear with 225/35/18 Nankangs up front and 255/35/18 Bridgestone Runflats in the rear. Thanks y'all. |
Drives: '05 Elise
Why not just get the TRD swaybar pair? I currently have the pair and plan to go stiffer in front. SCCA CS autocross car.
Proper tires will be a MUCH better performance increase for you though...
'05 Lotus Elise
'19 BMW M2C '22 Subaru WRX ex '15 Scion FR-S |
#3 | |
Panda Trueno
Drives: No twin now.
With such a huge stagger and mismatched tires.... I would
A) Buy proper tires in a matching set. B) You will probably need a larger rear sway due to the huge stagger. Car probably understeers now as it sits. Fine tune your suspension to your driving style, but you're basically following every step of a thread I remember. "How to screw up your ride and handling, step by step." |
#5 | |
#6 | |
You might also want to look at tires that are at least the same diameter as each other. Too much of a difference can make the traction control misbehave. Currently your rears are like 3/4" taller than the fronts.
#7 | |
Alexandrino_Auto
Drives: series.Blue
I run a Strano front sway bar with a WRX rear. I love it, but everyone is different.
It was a pretty popular setup a few years ago.
The Shadetree Project: I turn wrenches
buy a set of adjustable swaybars and you can tune it to your liking without having to buy multiple ones. I personally have Hotchkis but there are some others out there.
#10 |
StreetKart
Drives: 2014 Scion FR-S Monogram
I've been trying to find info on this. Have people shy'd away from this now? I'm on Hotchkis springs and would like to stiffen up some of the roll. Do you remember the specs of the strano bar?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#11 |
http://www.stranoparts.com/partdetails.php?PartID=928
iirc the Strano bar is relatively mild, a touch softer than the popular 20-22mm solid bars (Whiteline, Perrin, TRD/Eibach) and only a few are less than that, maybe the 19mm Perrin in the soft hole. This thread has some of the options, but it's not 100% and I'd double check the numbers. http://www.ft86club.com/forums/showthread.php?t=49659 Edit: If you go for it and decide to buy new, I'm going to offer that it's worth calling Sam up, his website is pretty clunky but it was great ordering parts from him over the phone. |
#12 |
Alexandrino_Auto
Drives: series.Blue
The Strano is also lighter than the stock bar, and obviously lighter than all the other aftermarket options. Mine took a few months to arrive because they are hand made to order in the USA. Customer service could be better, but if you're looking for the best compromise, and you're not in a rush, I highly recommend it. Order it today and have it on your car before next race season.
I'd think it isn't as popular because many owners of this car are more focused on getting the car as slide happy and as stiff as possible, instead of spending the countless hours it takes to properly set up a car for track or autoX duty.
#13 |
Drives: FRS
if you don't want oversteer shouldnt be looking at thicker RSB..
like many have mentioned already...SBs should be last thing to "fine tune" after all suspensions have been dialed in.
'14 Scion FRS
Tein Flex TE37 |
| Tags |
| combination, oversteer, sway bar, understeer, wrx |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 02:20 PM |
| PTUNING Front & Rear Sway Bar | Peace@Ptuning | Brakes, Suspension, Chassis | 18 | 03-11-2015 03:37 AM |
| Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 01:38 PM |
| front/rear sway bars | ramiram1984 | Brakes, Suspension, Chassis | 5 | 05-08-2014 06:33 PM |
| FS oem sway bar set front and rear | davebrus | Brakes, Suspension, Chassis | 0 | 12-20-2013 01:47 AM |
