Old 11-26-2016, 01:21 AM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Camber plates to use with stock struts and RCE Yellows
I'm looking for a camber plate solution that will work with my RCE Yellow springs and also not add any ride height in the front. I also don't want to spend like $600 on Raceseng CasCam plates... Are there any good options for me?
Thanks!
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 11-26-2016, 01:26 AM   #2
D_Thissen
D_Thissen's Avatar
Sub'd
Old 11-26-2016, 01:54 AM   #3
ysr50guy
ysr50guy's Avatar
Drives: brz
http://www.brz-parts.com/hvt-brz-camberplate.html
ysr50guy is offline   Reply With Quote
Old 11-26-2016, 02:22 AM   #4
gramicci101
Off Topic
RCE and Velox are both good options for less than Raceseng.
Old 11-26-2016, 03:17 AM   #5
Keenercarguy
Mountain Runner
But I'm pretty sure both raise the front ride height and since I'm on springs, and not coils, I can't compensate by adjusting the front height.
Old 11-26-2016, 03:54 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by ysr50guy View Post
@ysr50guy is all over that shit.
Old 11-26-2016, 03:58 AM   #7
Keenercarguy
Mountain Runner
Oh yeah I definitely saw those (thanks @ysr50guy), I'm just leaving the thread open for more viable options: if there are any. I'm disappointed nothing is in the $300 range that will work for us spring (poor) guys...
Old 11-26-2016, 04:03 AM   #8
Ultramaroon
not playing cards
I get your point but carving a cavity out of solid billet is way more expensive than cutting a flat plate. If there are alternatives, I bet they'll be about the same price.
Old 11-26-2016, 11:56 AM   #9
gramicci101
Off Topic
If you can get a set of hvt plates, go for it. They're no longer being made.
Also check the classified section.
Old 11-26-2016, 12:03 PM   #10
Cole
Not a troll
Cole's Avatar
i love mine
Old 11-26-2016, 03:35 PM   #11
Keenercarguy
Mountain Runner
Originally Posted by Cole View Post
Wow those are so cheap, actually almost scary cheap lol... But do they 4x4 the stock front shocks because like 0.8* of camber isn't worth it to me if they 4X4 the front.
Old 11-26-2016, 05:09 PM   #12
Cole
Not a troll
Cole's Avatar
Nope. They keep it the same, or might slightly lower the front. I'm using them with Tein S-Tech springs.
Edit: They also give about 1.5-2 degrees of camber. With my camber bolts and the top hats, I have -3*.
Old 11-26-2016, 06:02 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Thanks!
Are you tracking the car?
Old 11-26-2016, 07:14 PM   #14
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Our top hats were designed directly around OEM CAD and do not alter ride height. That being said, due to OEM unit being rubber and having compliance where ours has none, it does appear to vary ever so slightly from this variance (3 or so mm it seems).
Thanks,
Eric
VerusEric is offline   Reply With Quote
Camber plates with stock struts kbye Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-29-2016 02:37 AM
SOLD: Pre-assembled stock struts with RCE Yellows + Whiteline Com-C top mounts ATL BRZ Brakes, Suspension, Chassis 12 08-07-2014 10:23 PM
Front stock struts/bolts max camber Q.. OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-15-2013 05:45 PM
FS: RCE Yellows on stock struts (complete package) sw20kosh Brakes, Suspension, Chassis 6 07-02-2013 06:02 PM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 09:33 AM
