Old 01-12-2017, 09:36 AM   #1
Naeblis
Drives: Subaru BRZ
DDX916WS in 2013 BRZ
Hey, I just bought the Kenwood DDX916WS to replace the CA-FI radio I've had for a few years. It was really easy to swap out, the only problem I had was my car battery actually died while I was testing out the radio, so had to run and get a new battery (at first I thought I did something wrong)! The radio sounds great, is very responsive, and I really like the android auto. I'm not quite doing installing it, since I have the usb coming out the front at the moment for android auto. Need to figure out if I can just hook that into the existing USB, or have to run it some other way. And then I need to finally install my backup camera.
You can see I have the USB just coming out from under the dash here. I also have the mic cord coming out, but it's not really noticable, and I'll probably leave it there
Home screen showing android auto icon since my phone is plugged in
Spotify on android auto
Naeblis is offline   Reply With Quote
Old 01-12-2017, 11:03 AM   #2
armstrom
Drives: none
Do you find it annoying that the controls are on the right side of the screen? This model was only sold in countries with RHD so it makes sense for them...
armstrom is offline   Reply With Quote
Old 01-12-2017, 11:29 AM   #3
Naeblis
Drives: Subaru BRZ
So far no, but I've only had it for a day now. I also haven't tried the gestures yet, so don't know if they work. It probably would be a little nicer for changing volume if it was on the left, but I don't think it will be a big deal. Mostly I'll be using android auto, so other than the volume I won't be using the buttons that often.
Old 01-12-2017, 11:30 AM   #4
jasonojordan
Drives: 2013 satin white brz limited
They make a plug and play port setup that replaces the stock remote IO with the same usb and aux port with standard connections that plug into any aftermarket radio.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jasonojordan is offline   Reply With Quote
Old 01-13-2017, 01:32 PM   #5
Naeblis
Drives: Subaru BRZ
Thanks jason. I bought that, hopefully will have it saturday and can finish the install. As for the buttons being on the right side, it might be an issue in a larger vehicle, but with the BRZ, the right side of the radio isn't really a stretch. It's no further than when I'm shifting in 5th/6th. So I don't see that as a problem.
Old 01-21-2017, 04:39 PM   #6
Fd3sr2
Drives: 2017 brz limited
did you wire the steering wheel controls? i saw they made it easy, or look easy at least.
Fd3sr2 is offline   Reply With Quote
Old 01-21-2017, 07:16 PM   #7
Cole
Not a troll
Cole's Avatar
What steering wheel controls?
Old 01-21-2017, 07:44 PM   #8
Eman
Drives: 2013 Scion FR-S 10 series
I ran the mic to the stock location on mine and mounted the extra usb to a panel mount in the glove box. I posted a couple pics of it here under the thread "glove box usb". I used the same replacement for the dash mounted usb/auxiliary, works well.
Eman
Sent from my SM-G920F using Tapatalk
Eman is offline   Reply With Quote
Old 01-21-2017, 08:58 PM   #9
Fd3sr2
does yours not have audio controls on the steering wheel?
Old 01-21-2017, 10:39 PM   #10
Fd3sr2
in the wiring, does the front channel split and power the dash speakers and send signal to the door speaker amp?
Old 04-11-2018, 12:04 AM   #11
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
Did you have to replace that section of the dash panel or did you use the existing one from your ‘13 Brz? I have a ‘14 and want to do the same but wasn’t sure if it would fit my existing dash panel.
ModalSoul37 is offline   Reply With Quote
Old 04-11-2018, 01:31 AM   #12
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
2017 was the first year to have steering wheel controls...
NCtoBRZ is offline   Reply With Quote
Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 RallySport Direct Engine, Exhaust, Bolt-Ons 21 06-03-2015 03:21 PM
Cricket-Fest 2013!! Calling All FT86s! Pure's Last Meet and Dyno Day of 2013! Pure Automotive Mid-Atlantic 274 10-15-2013 11:48 AM
2013 FT86CUP *bonus round* Streets of Willow Springs, 5/26/2013 CSG Mike Tracking / Autocross / HPDE / Drifting 47 05-24-2013 02:14 PM
ITR Expo 2013 - Mid Ohio - Sept 9th/10th 2013 - 2 day HPDE Dave-ROR Tracking / Autocross / HPDE / Drifting 2 03-16-2013 07:13 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 09:03 PM
