| Engine Swaps Discussion of engine swaps. |
Drives: 2013 Scion FR-S, 2014 Scion tC
2AR-FE
Can anybody point me in the right direction with my idea for a 2AR-FE DD?
Sporadic Member
Drives: 2016 Halo FR-S M/T
Aside from more torque, what do you find more appealing about the 2AR?
Drives: 2005 Toyota Camry
What license?!
Drives: 2015 Scion FR-S
So no Camry can never pull on a FT86 ever again. ![]() [ame="https://www.youtube.com/watch?v=T3_wvXDCQRM"]https://www.youtube.com/watch?v=T3_wvXDCQRM[/ame]
Cause the 2ar-fe is basically a 2jz with two less cylinders.
Ever seen Fredric Aasbo's 2AR from Papadakis Racing? |
Dismember
Drives: 2013 Red Scion FR-S
There are two engines worth swapping: 2JZ and LS?. Everything else is inferior and/or too expensive.
The Gunshine State
Drives: '14 BRZ Limited
Can't blame a guy for wanting to be different.
Personally, I would do a rocket engine.
![]() Current DD: M235i |
Those are some of the best engines but I'd like to have 800hp come from an 51lbs 4 cylinder (empty of course), and still have room under the hood for more.
#9 | |
Drives: 2001 Impreza 2.5 RS
Colin Beck
#10 | |
http://www.motoiq.com/MagazineArticl...ta-Engine.aspx |
#11 | |
#12 |
#13 |
The Gunshine State
3S-GTE is known as the 4-cylinder 2JZ.
#14 |
The 2AR is the first I4 I've actually liked, never took any other 4 cylinders into consideration, so I didnt do too much research into other 4 cylinders. Always liked the body of the MR2's, just haven't taken a look under the hood of one.
| Tags |
| 2arfe, 4 cylinder, daily driver, frs, swap |
