Drives: 86
STARTER rom for FRS/BRZ/GT86/86 2013-2016
Hello
after long time looking for this rom . Finally i found it idk if it worl or not .iam not test it yet but it should work fine this Rom is for recover bricked ECM . so dont use it for normal prosseor . it will work for all kind of roms MT and AT . all codes. remember it is only for recover . flash it . the reflash WITH base rom flash it with SH boot mode (full rom flash) Last edited by aagun; 02-11-2017 at 04:50 PM. |
ok,
so this rom contains working 0000-7FFF code area ? did you get your ECU going again with SHBOOT and this rom ? Thanks |
#3 | |
Drives: 86
yes it is full rom 0x0000 - 0x14FFFF NOT yet . my ecu need same soldering . to be ready for unbrick it i believe this rom will work right with out any issue . i was looking in it to be sure that will work . and i found it includes our microcontroller code sh72531 anyone had bricked ecu have no things to lose if try it |
#5 | |
To use that rom you need to remove ecu, make a circuit to simulate watchdog timer and connect and power ecu directly oitside car. Note as soone as you pit ecu in SH boot mode it deletes both the Tune area and the boot area in ecu and then you need to flash both those areas back. https://www.ft86club.com/forums/showthread.php?t=95334 as these ecu are very hqrd to brick unlike the older wrx ecu, for most people with a taxtrix if your very unlucky amd manage to brick ecu its likely easier and cheaper to buy a used ecu and just flash it with correct rom like normal and just bin the bricked ecu |
| █ █ █ 2013-2016 Scion FR-S BRZ GT86 Rocket B V3 Style Trunk Spoiler █ █ █ | Angela.IKON | Exterior Parts - The Rest | 38 | 12-16-2016 06:00 PM |
| 2013 BRZ replacement starter, correct part help | sftateofmind | Issues | Warranty | Recalls / TSB | 25 | 07-21-2016 11:12 PM |
| FRS/BRZ/GT86 car events Quebec Summer 2016 | FRS864Life | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-30-2016 02:04 PM |
| TMG GT86 CS-R3 Rally Car @ TAS 2016 | mav1178 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 01-17-2016 08:04 PM |
| FRS 2014 not 2013 Same Bypass for Starter? | Mikeez | Electronics | Audio | NAV | Infotainment | 0 | 04-10-2014 11:59 AM |
