Drives: 2017 Subaru BRZ PP
Spacers for Performance Package wheels and Megan tie rod ends
I just bought a BRZ PP and would like to purchase some wheel spacers. I need the spacers to push the wheels out far enough so that I can use the Megan Racing tie rod ends and not rub the sway bar at full lock. I also need the outside of the tire not to rub the fender.
Stock ride height and soon will have 1-1.5 degrees negative camber in the front only. Any suggestions? Alternatively, if anyone knows how much spacer is needed with the regular stock wheels for the megan tie rod ends to work maybe I can work backwards from there. |
| Specs for BRZ Performance Package wheels? | ~el~jefe~ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 04-17-2020 07:31 PM |
| Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue | DaJo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 09-25-2018 06:12 PM |
| Megan Racing Rack Ends | sandman126 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-15-2018 01:25 PM |
| WTB: OEM 2017 Performance package wheels | mjanmohammad | Want-To-Buy Requests | 1 | 03-03-2017 03:35 PM |
| RacerX RUCAs, FLCAs, tie rod ends & Megan rear toe arms | pokemonphil | Brakes, Suspension, Chassis | 5 | 09-08-2016 06:17 PM |
