Old 04-12-2017, 01:11 PM   #1
DIF
DIF's Avatar
Drives: FR-S in Firestorm, Katzkin, alpine
FRS vs Camaro Handling
My friend just bought a Camaro SS 1LE, and insists it will handle better than an FRS/BRZ/86. What are your thoughts folks?
DIF is offline   Reply With Quote
Old 04-12-2017, 01:13 PM   #2
timmydatooth
Drives: Scion Frs
considering its a lot heavier than our twins. probably not.
timmydatooth is offline   Reply With Quote
Old 04-12-2017, 01:22 PM   #3
jvincent
jvincent's Avatar
Set up some cones in a parking lot and challenge him to a slalom.
Old 04-12-2017, 01:38 PM   #4
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
If your car is stock it'll do everything your car can do and more.
murdoc is offline   Reply With Quote
Old 04-12-2017, 01:42 PM   #5
DarkSunrise
DarkSunrise's Avatar
Depends what you mean by handling.
But solely in terms of lateral grip (with your FR-S on OEM touring Primacy's or all-season Turanzas), he's right.
2022 BRZ Build
2013 FR-S Build
Old 04-12-2017, 01:50 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Didn't one of the new Camaros do really well on the Nurburgring track?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-12-2017, 01:55 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Define "Handling"? Term "Handling" can define differently by everyone. Because it have different meaning for everyone. Even if you're talking about weight shift/transition can change w tire quality (& suspension). Corner speed or how fast can go through the course/track can be different w driver.
So again, define "handling"
Old 04-12-2017, 02:02 PM   #8
TommyW
TommyW's Avatar
Drives: '13 Whiteout
As mentioned "handling" is relative to opinions. Camaro is bigger and heavier so not a nimble.
Old 04-12-2017, 02:04 PM   #9
Dougboy
Dougboy's Avatar
Drives: acura tsx
A 1LE will beat an M3. Can an 86 beat an M3?
Dougboy is offline   Reply With Quote
Old 04-12-2017, 02:09 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Why don't you two switch cars and find out?
Current DD: M235i
Old 04-12-2017, 02:14 PM   #11
funwheeldrive
The Camaro should win on any course that's not the size of a parking lot.
Assuming the Camaro driver can see where they are going.
Old 04-12-2017, 02:38 PM   #12
Have you driven the latest incarnation of a Camaro? They are very nimble. The size and weight is way down and very deceiving when you just look at the numbers.
Old 04-12-2017, 03:24 PM   #13
PNW FRS
PNW FRS's Avatar
Considering v6 1LE
I test drove one last weekend.... it's pretty darn nice!! The v6 with MT is pretty good and the "handling" is on-par with the 86. The "difference" from the driver's seat is that the Camaro definitely "feels heavier" (cuz it is...) so don't expect it to feel as "nimble" as the 86. But that said... one can push the 1LE hard into a turn and it's solid...with just a hint of understeer.
"Lightly optioned" beyond the 1LE package, it's only a few thousand more than a new 86/BRZ.
Adding a v8 to the mix is not really necessary unless one has the need to lay down a lot of rubber. The extra weight up-front (with v8) definitely can be "felt' when in hard turns.... BUT... it's still good and fun!
My only complaint about the Camaro in general is the SMALL trunk. There's no carrying more than two small suitcases let alone 4 wheels/tires in the back like one can with a 86!!
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 04-12-2017, 03:30 PM   #14
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Even if the Camaro is better at "handling" , does that make you feel any different about your car?
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
FRS then Camaro SS 1LE? stock Scion FR-S / Toyota 86 GT86 General Forum 25 05-26-2016 05:07 PM
Camaro for FR-S whamslam3 Other Vehicles & General Automotive Discussions 26 06-18-2014 09:53 AM
frs or camaro failingpig FR-S / BRZ vs.... 77 02-22-2014 01:58 PM
FR-S vs 312 hp Camaro? Gill FR-S / BRZ vs.... 32 03-31-2012 08:56 AM
