Old 04-23-2017, 09:41 AM   #1
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
2017 BRZ and Perrin Oil Cooler Install
Perrin OC was just added for track events to my 2017 PP BRZ by my mechanic. While RSD listed it as compatible with my car, it only is "sort of." The new airbox has a square cover and takes up the space for the oil lines coming off the sandwich plate. He called to tell me my options were to leave the unit off the car & return it or find an older style air box and he'd zip tie my current one in place, which is what we did. Turned out finding a used airbox wasn't as easy as I assumed it would be and, with a track weekend approaching, I decided to take the matter into my own hands and hack the box. I bought a roll of DEI Floor and Tunnel Shield and the vendor threw in a roll of heat tape, which ended up coming in handy to cover the edges of the DEI product. $40 got it done.
JSube is offline   Reply With Quote
Old 04-23-2017, 10:18 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I definitely would have waited to install the oil cooler instead of doing that...
Old 04-23-2017, 02:25 PM   #3
JSube
JSube's Avatar
Oil Cooler
Well, it's a $50 part & altering it gets me on track. Seems worth it to me
Old 04-26-2017, 02:07 AM   #4
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Just a heads up but that tape will start to come up from the edges at some point, it's really annoying to me. (assuming its DEI cool tape)
Trueweltall is offline   Reply With Quote
Old 04-26-2017, 05:26 AM   #5
Just swap in a 13-16 intake like I did.
Old 04-26-2017, 08:08 AM   #6
JSube
JSube's Avatar
Thanks, I'll be keeping an eye on it
Old 04-26-2017, 08:11 AM   #7
JSube
JSube's Avatar
Right, that's still the plan. This just gives me time to find one that's in good condition and realistically priced.
Old 04-26-2017, 03:19 PM   #8
If you can't source one out there, I can find a used one for you out here and ship it to you.
Old 04-26-2017, 04:44 PM   #9
CSG David
CSG David's Avatar
We found one within an hour of looking for one. Let us know sir.
Old 04-26-2017, 08:43 PM   #10
JSube
JSube's Avatar
Used Airbox
DAAAAAAAMN! You Cali people have all the hook ups ! Let me know the details, etc, I'm in.
Old 04-28-2017, 01:22 AM   #11
CraftyObeseCrunchyKitty
Drives: Blue ZC6
This may be less expensive than a new airbox.
CraftyObeseCrunchyKitty is offline   Reply With Quote
Old 04-28-2017, 12:36 PM   #12
OND
OND's Avatar
Drives: 2023 BRZ
Parts vendors will hate me for saying this, but I dont think a single track event without an oil cooler near KY in spring is going to do any damage to the engine.
OND is offline   Reply With Quote
Old 04-28-2017, 05:57 PM   #13
mkivsoopra
Not likely to cause any damage, but I would hurry to get it installed too, if I had most of the parts on-hand. I did a track day without an oil cooler in December at Laguna Seca in 50°F weather and still hit 275°F+ oil temps.
mkivsoopra is offline   Reply With Quote
Old 04-28-2017, 06:50 PM   #14
OND
OND's Avatar
Drives: 2023 BRZ
When I was monitoring my oil temps at 50F weather (this February I think), I never saw anything above 250-255F. The temps will depend on a lot of things like the track layout, driver, session length etc. That's why I think people should get a $20 obd adapter and a $10 iphone app to monitor their temps before investing $600+ on an oil cooling system (or going thru the hassle OP went thru).
I also dont see the fuss about 275F oil temp while Corvette guys are in the 300F range, but that's a whole other topic...
FS: Vortech Supercharger, Perrin Oil Cooler, Perrin Overpipe MrTranxD Engine, Exhaust, Bolt-Ons 14 08-17-2016 12:20 PM
Oil Cooler install in the GTA.. Skurj CANADA 53 06-24-2015 03:51 AM
Perrin Oil Cooler Install & Snorkel Mod BC-Boy Engine, Exhaust, Transmission 4 05-14-2014 12:06 PM
Help! Oil Cooler Install brillo Tracking / Autocross / HPDE / Drifting 13 07-17-2013 05:55 PM
Perrin Oil cooler install review LeeMaster Engine, Exhaust, Transmission 3 03-14-2013 11:41 PM
