Old 07-18-2012, 06:41 PM   #1
fasteddy
Clutch dump at 5000 RPM?
In at least three reviews of the BRZ they talk about how to launch it. They all seem to conclude that dumping the clutch at 4500-5500 RPM is the best.
Well that seems kind of hard on the car to me. I have not tried it yet.
How about you guys? How long with the clutch last if you do that regularly?
Pat
fasteddy is offline   Reply With Quote
Old 07-18-2012, 06:47 PM   #2
GNS
Drives: .
Dumping the clutch regularly is not good for your car. For any car. Don't know why you'd want to do it regularly.
GNS is offline   Reply With Quote
Old 07-18-2012, 06:57 PM   #3
tjdiz92
Drives: 2013 Argento FR-S MT
there is no situation where you could possibly dump the clutch REGULARLY but you have to do some pretty fancy feathering when you dump the clutch at that high. I'm real inexperienced did that and just did a pretty nice burnout. I launched best at 3500
2013 Argento Scion FR-S M/T 15% tint-6k HID headlights-6k HID blinker Switch backs-LED domelight-LED reverse lights-LED license plate light-Gloss black roof-Hertz audio components w/ 2 10 inch kicker L'3s.
tjdiz92 is offline   Reply With Quote
Old 07-18-2012, 08:18 PM   #4
jeebus
Drives: 2015 Mustang GT (on order)
((RPM / curb weight) * # gears) * # tires driven = 22 times ok?
jeebus is offline   Reply With Quote
Old 07-18-2012, 08:25 PM   #5
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
IMO the true acceleration of this car happens to be launching this car around 3k rpms. I saw a video of a manual BRZ launching at 3k rpms and it got to 60 in 6.8-6.9 seconds.
SUB-FT86 is offline   Reply With Quote
Old 07-18-2012, 09:16 PM   #6
Opposed
Drives: 2013 Asphalt FR-S
that's pretty slow still. Motortrend did a 5k launch and got 6.2. Another company on here did redline launches at the drag strip and did a 14.7
Opposed is offline   Reply With Quote
Old 07-19-2012, 08:08 AM   #7
SUB-FT86
86 Member
Yeah but I was talking about playing it safe on a daily basis.
Old 07-19-2012, 09:05 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Around 4.5-5 was best for me with 235 ad08s so 3.5 sounds faIr for the junk oem tires.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-19-2012, 09:16 AM   #9
Opposed
Understood. It's a gamble either way. One guy might break something on the first dump, and another guy 8 years from now with 100k miles on it will done several clutch dumps and have no issues. Its one of those things to me that is hard to measure the wear. To many variables. Like when people say redlining your car causes more engine wear. I redlined my S2k a couple times a day for the 5 years I had it and 100k miles, and compression test and leak down was perfect before I traded it in.
Old 07-19-2012, 02:23 PM   #10
LSxJunkie
LSxJunkie's Avatar
Drives: Car
All hard launches are rough on the car. A high rpm quick slip is for drag racing. You only need to do this at a prepped strip.
LSxJunkie is offline   Reply With Quote
Old 08-22-2013, 11:43 AM   #11
B1FR-S
B1FR-S's Avatar
Drives: 2013 Scion FR-S Raven
So what is a quick slip??
B1FR-S is offline   Reply With Quote
Old 08-22-2013, 11:50 AM   #12
DarkSunrise
DarkSunrise's Avatar
Some of the more serious autocross guys have done dozens of hard launches on sticky 245+ width street tires so they should have some insight on this. I believe axles might be an issue.
The last time I autocrossed, I did a hard launch at 3500 rpm on mild 215 width street tires and got mostly wheelspin in 1st. That was pointed slightly uphill too.
2022 BRZ Build
2013 FR-S Build
Old 08-22-2013, 12:14 PM   #13
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
If you're talking "clutch dumping" it really makes you look like a goof.
As for properly launching the car, I run 245/40 Bridgestone RE-11A in Autocross and I launch it at 4000. There is no "dumping" the clutch, I feather it while keeping as close to wot as possible and accelerating as fast as possible without spinning the tires. 5000 would be better as the engine would be out of the "torque dip" and you would achieve the best possible launches there. I just limit my launches at 4 and save the wear and tear and take the .1 second loss.
Properly launching the car just wears your clutch faster, "dumping" it is slow and with sticky tires you will break things.
Thorpedo is offline   Reply With Quote
Old 08-22-2013, 12:35 PM   #14
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I autoxed my Integra GS-R (140-190k miles on the odometer) for 4 full seasons and would usually launch around 4000 rpm. At the drag strip (15-20 runs total) I would launch around 6000 rpm. And just for kicks a few times on the street I've launched as high as 7000 rpm. Never had any related drivetrain wear issues. I had the inner axles replaced 6 months ago (car currently has 300k) but that's normal at this point. Also I've got over 150k on this clutch, and still doesn't slip (OEM clutch, 2nd on this car).
I think the BRZ should be fine launching at 4000-5000 rpm without having to worry about drivetrain components. However I would be leery of Subaru agreeing and honoring the warranty "IF" something were to break.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Anyone else above 5000 miles too? Superhatch BRZ First-Gen (2012+) — General Topics 32 06-28-2012 01:08 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
5000 to spend on what? MtnDrvr86 Other Vehicles & General Automotive Discussions 29 03-18-2010 05:10 PM
