Drives: 2016 Asphalt Scion FRS
Exhaust system, what next?
So I've currently installed my exhaust, running an (Invidia N1 Catback exhaust) was wondering in which order should I mod next between UEL headers/front pipe/overpipe. Moreover, what piece would show the largest change in terms of sound & performance. Planning on purchasing all of these parts in the future.
UEL header. Lots more noise and performance with a tune
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Drives: 2015 Asphalt Scion FR-S
From my understanding, I always go Catback then work your way to the front of the car.
Catback - Frontpipe - Overpipe/Headers. The piece that will give you a noticeable Performance gain is the Headers since it will Eliminate or Reduce the infamous torque dip Drastically. |
#4 | |
So many people get catback first, then get a catless header to realize it's too loud and end up getting another catback. |
Drives: 2013 Firestorm FR-S
Sound > Power.
I'd plan everything in advance to prevent going down blind alleys. The Invidia N1 will be really loud when paired with a header, and different combinations of header, overpipe, front pipe, and cat-back exhausts can sound very different, so plan accordingly. I did my entire exhaust and tune at the same time, but if you can't do that then keep in mind that you can add the overpipe, front pipe, and cat-back exhaust without a tune, but you'll need a tune when you add a header - this sounds obvious, but it may factor in the order you do things.
My exhaust consists of: - ACE 4-2-1 Type-A 350 equal length header (ceramic thermal coated) - Motiv catted front pipe (ceramic thermal coated) - Blitz Nür Spec R stainless steel exhaust - EcuTek Pro ECU programming and datalogging kit - Delicious Tuning - ECU reflash/stage 2 Good luck and have fun! |
| Tags |
| catless, exhaust, headers, invidia, uel |
| Exhaust Advice. I want a loud exhaust system please help | Rambo2469 | Engine, Exhaust, Transmission | 28 | 04-21-2017 03:41 PM |
| FI Exhaust - Valve Exhaust System GT86,BRZ,FRS | Chefsache | Engine, Exhaust, Bolt-Ons | 6 | 10-06-2016 02:56 AM |
| Exhaust System/Exhaust Manifold Removal and Replacement | GrimmSpeed | DIY (Do-It-Yourself) Guides | 52 | 11-11-2015 10:30 PM |
| need exhaust system | DAKA | Southern California | 10 | 02-26-2015 06:37 PM |
| HELP: What exhaust system is this? | all_aboard | Engine, Exhaust, Transmission | 17 | 02-15-2015 12:37 PM |
