Melted Bushings
I had to end a track day early last weekend because my 22mm Whiteline swaybar passenger side bushing melted due to its proximity to my ACE A350 ceramic coated header overpipe. It wasn't just a little melted either. The top half of it is completely gone. Has anyone else come across this and found a solution? The steering linkage is also very close and shows where it may be hitting in extreme instances. Just wrap it? Any advice?
Drives: 2 Subarus and a 2013 FRS
Yikes
Drives: 2013 Scion FRS
Pictures? Have never heard of this issue on our platform yet. Surprised the stock ones aren't melting on other people's cars
Sent from my HTC6535LVW using Tapatalk |
Drives: '13 BRZ
This is the downside of modding your car. Pics please.
Señor Member
The whole area near the overpipe is very cramped. I haven't seen what it's like with the ACE header. Can you take a photo? You may be able to put some heat shielding near the bush.
1974 TA22 Celica
2013 86 GT |
The Fail Boat
Drives: CWP S.B.
err your exhaust is touching...? how is that a surprise.....
![]() see if you can move the exhaust upword a bit, i had this problem with my header when i just installed it, i end up sorta pushing it up while installing the whole thing again. Cuz my overpipe was rattling my car under acceleration. *such a given
Señor Member
1974 TA22 Celica
2013 86 GT |
Drives: 2015 FR-S
Does any other header get that close to the sway bar to touch or is it just the Ace?
#10 |
Drives: Toyota 86 GT
what are your exhaust gas temperatures?
this is partly why I'm considering leaving my overpipe stock with its headshields. |
#11 |
Honarary Member
Drives: 2015 FRS
I thought ceramic coating was supposed to help deal with heat issues... damn OP! that looks horrible.
#12 |
Drives: 2014 GT86
If there is contact, due vibration at that point coating gets damaged anyway, so how can it protect? +with contact there is much more heat conducted then via heat radiation, if there had been even though small but gap with air.
Problem with that little space to work with is how to get long enough runners for most efficient exhaust gas scavenging. Nameless tucked excess in front of engine, Ace - using overpipe part. No clue, which approach is better, but from this case it seems that it's always worth double check any clearance issues one may have, not just when vibrations between parts can be heard. |
#13 |
not playing cards
You guys are mixing up the sequence of events. The sway bar came into contact with the overpipe after the bushing melted.
#14 |
indeed, Ultramaroon. There was no contact prior to the bushing melting. I had more important things to monitor during my track day than EGT. I had 4 or 5 20 minute sessions at Florida International Rally and Motorsports Complex. Each run was 20 minutes apart. I think a majority of the melting happened after parking (4 cool down laps). I didn't hear it banging while I was still on track. I'm still running the stock front pipe, waiting on my ACE unit to come in. The lack of flow past the overpipe could have contributed to this.
| Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 06:32 PM |
| Clutch Release Bearing Melted | Haulin | Engine, Exhaust, Transmission | 37 | 05-29-2016 07:35 PM |
| Buddy Club Tails Damaged/Melted? | Krazy | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-07-2016 12:11 PM |
| Perrin exhaust with added benefit of melted plastic | s30series | Engine, Exhaust, Transmission | 3 | 09-12-2014 09:44 PM |
| Muffler delete on track (melted bumper?) | celica73 | Tracking / Autocross / HPDE / Drifting | 12 | 04-01-2014 05:27 PM |
