Old 08-16-2017, 06:22 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
How to fix fuel starvation on left hand turns - Verus Fuel Door
[ame="https://www.youtube.com/watch?v=Wc8goq7vXLI"]How to fix Fuel Starvation and Upgrade Fuel Pump - YouTube[/ame]
Verus Engineering (Formerly Velox Motorsports) recently released a fuel door that fixes the fuel starvation problem that occurs during high-G, left hand turns. This problem is more apparent with cars that have larger fuel demands with E85 or forced induction.
The starvation usually occurs when the tank is below 7/8th or 3/4th of a tank (which is probably most of the time, unless you fill up frequently). But with the fuel door installed, you’ll be able to run lower fuel levels for lower weight and enjoy those long left hand corners.
Inside the fuel tank the fuel pump sits in a basket. The access panel for the fuel pump is under the rear seat on the drivers side. Once the fuel pump assembly out, it can be disassembled by hand, and the fuel door clips right into place with the help of some needle nose plyers.
Since we already had everything taken apart we decided to upgrade the fuel pump using the AEM 320LPH high flow pump that is E85 compatible if we choose to go that route in the future. But to install it we needed Deatschwerks 9-1010 fuel pump install kit.
All in all this was a much easier install than it initially looked. Hope the video helps any of you that decide to do this to your car.
FT-86 SpeedFactory is offline
Old 08-16-2017, 10:07 PM   #2
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Great fuel pump install video. Removed all doubts as to doing this myself.
One question, did you do anything to the access cover sealing material to reseal the cover?
Brzzee is offline
Old 08-16-2017, 11:43 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Bought one today.
Sapphireho is offline
Old 08-21-2017, 04:22 PM   #4
FT-86 SpeedFactory
Naw there is plenty left over to seal back up. Just be careful not to get on your hands or cloths that stuff is a pain.
Left Hand turn fuel starvation on WOT Huehuecoyotl Tracking / Autocross / HPDE / Drifting 105 08-05-2021 08:12 PM
Fuel Starvation? Lunatic Tracking / Autocross / HPDE / Drifting 37 03-29-2018 12:47 AM
High boost, e85, fuel starvation on a road course: What's everyone doing in 2015? Xero-Limit Tracking / Autocross / HPDE / Drifting 6 06-16-2015 01:45 PM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 12:19 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 11:14 AM
