Old 09-27-2017, 04:22 AM   #1
Xaftos
The Stripes Add HP
Xaftos's Avatar
Drives: 2017 Toyota 86 860
RomRaider help? ECU definition cannot be found even when present?
Hi guys!
As the title says I'm currently having issues with RomRaider not detecting or having incompatibility issues with my definition. I have added the .xml for my tune provided by Shiv into the definition manager, applied and saved, so all should be good in that regard, correct?
Well, when trying to open my .bin image, it brings up the error "ECU definition not found". I'm not sure if I'm just missing something stupid, or if my .xml and .bin are incompatible for whatever reason, but I need some assistance regardless.
Any ideas as to what may be causing my problem?
Here are some screen grabs of my RomRaider to show that I'm doing everything hopefully correct.
Thanks!
Xaftos is offline   Reply With Quote
Old 09-27-2017, 05:04 AM   #2
stefodrom
stefodrom's Avatar
Drives: GT86 AT 2013
i got this message when the Cal ID's are not matching.
Open the Xml with a notepad and look for the vehicle Data and check if it has the same Cal ID as your Rom
stefodrom is offline   Reply With Quote
Old 09-27-2017, 05:05 AM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Rom is K00D and definition is F00D, therefore you don't have a definition for K00D.
Old 09-27-2017, 05:37 AM   #4
Xaftos
The Stripes Add HP
Xaftos's Avatar
Thank you both for your responses. I have changed the ID's to K00D and it seems to have detected and read the file. However, I get an "ERROR - Data Mistmatch" window that pops up now saying that the Definition file or ROM image may be corrupt. I'm assuming this is a result of me just changing the F to a K? Should I be worried about this? It comes up for every folder within the ROM. Here is an image for reference as to what I'm seeing.
Old 09-27-2017, 05:41 AM   #5
Xaftos
The Stripes Add HP
Xaftos's Avatar
Seems to be working okay I think? I'm still able to load a lot of tables, but maybe some (or a majority) are excluded due to this data mismatch error?
Old 09-27-2017, 05:47 AM   #6
Xaftos
The Stripes Add HP
Xaftos's Avatar
Alright final post regarding this issue which seems to have been resolved in a much easier fashion than I expected. So my main goal with all of this was to modify my ROM to allow my car to backfire, which it pops once when shifting at high RPM but that's about it. More pops when releasing the accelerator would be nice. Any idea how to accomplish this given this table? I don't think the numbers on the left side are supposed to be that high, but hell do I know? What numbers should I change to accomplish this?
Old 09-27-2017, 06:00 AM   #7
stefodrom
stefodrom's Avatar
Do not use this Def file, its a wrong one.
For sure you can open it editing the Cal ID.
But the storage adresses are not matching your rom, and thats why it doesn't display the correct values
Look for a "real" K00D Definition and do not edit something with this one
Old 09-27-2017, 06:30 AM   #8
Wayno
Wayno's Avatar
Rom is K00D and definition is F00D, therefore you DO NOT have a definition for K00D.
Old 09-27-2017, 07:22 AM   #9
steve99
Every rom calid has tables in differnt locations, you cannot just change the calid in a def and expect it to work.
This is an easy way to brick your ecu.
Please read the Romraider tips link below.
Only use the KOOD def that came​ with your tune from shiv, if you did not get a def from shiv then you will need to ask him for the correct def
Old 09-27-2017, 07:13 PM   #10
Xaftos
The Stripes Add HP
Xaftos's Avatar
Lmao that would've been bad then, aye? Well I've emailed Shiv asking for the K00D file as opposed to the F00D file and hopefully I get it relatively soon.
Thanks guys!
2017, oft, romraider, tune, tuning
Edit OFT Definition for RomRaider blackspike Software Tuning 7 02-13-2016 04:18 AM
Definition of rice? Hot Lava Off-Topic Lounge [WARNING: NO POLITICS] 42 05-30-2014 04:41 AM
ECU table functions and definition of tables brn12345 Software Tuning 7 11-14-2013 09:45 AM
E46 M3 photo/video shoot by Project Definition DTMAUTOBODY Other Vehicles & General Automotive Discussions 0 06-18-2013 08:00 PM
AS1 Definition? nixeighty6 Scion FR-S / Toyota 86 GT86 General Forum 93 01-12-2012 02:56 AM
