Drives: FJ Cruiser
Bolt Pattern Woes
Ok.. so I don't have a BRZ/FR-S, but I'm in love with the car. I plan on eventually getting one so I'm already plotting and planning and one thing has me anxious... the odd choice in bolt pattern for this car. I don't know why Toyota/Subaru chose 5x100 for this car instead of the much more prevalent 5x114 or 5x120. I've already found several wheels that I'd like that are not offered in 5x100.
So the question is... do we think that the FT-86 platform will be popular enough that wheel manufacturers will begin offering the size in more of their designs? |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
5x100 was the size with 2000-2005 VWs and there was tons of selection. So I'd imagine if it becomes popular again the wheel brands would be crazy not to jump on board. But it takes time, and hopefully some other models will use it as well (any of the upcoming small cars)
Subaru WRX is the answer.... 5x100.
![]() Lots of wheels in the works with the right offsets for this platform. |
Drives: Whiteout FR-S
I'm having to keep this in mind with lots of other parts too, patience is key when dealing with a new model i don't want to end up buying the same parts multiple times from different manufacturers.
#5 | |
Drives: CBS BRZ Limited
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I was used to the problem of finding good lightweight 5x100 years ago when I drove Neons, but back then the issue was with finding light 14" or 15" wheels. Thankfully there are years of VW and Subaru cars that used 5x100 years in similar sizes, so there are at least some wheel models available, although not nearly as widespread as 5x114 (or 4x100).
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
Drives: FJ Cruiser
I really like the Konig SSM wheels.... hoping they come out with a 5x100 pattern.
When I was searching... I literally found hundreds of choices in 5x100. Tirerack alone had like 235 different wheels to choose from.
2013 Scion FR-S Raven MT: http://www.ft86club.com/forums/dto_g...ehicle_id=1141
--This tagline is umop episdn |
Drives: FJ Cruiser
#10 | |
Hope you find a good set you like... I, however, managed to find 5 I really liked and then began eliminating one by one til I got the the set I ordered up... and yes, yes, it needs a drop... and cleaned... The wheels were only on for like 5 minutes and it was raining...
#11 |
Drives: FJ Cruiser
What were the other 4?
#12 |
Drives: 2007 saturn ion(dd)
Rpf1 are coming in 17x9 this winter
2014 FRS
#13 |
Drives: FJ Cruiser
#14 | |
Drives: 2013 Argento Silver Automatic FR-S
Anyway, I'm looking to go lighter and smaller, 16s probably (but something that makes the rear at least flush with the fenders). Looks are a secondary concern. |
| What other vehicles use a 5x100mm bolt pattern? | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 09-13-2014 05:42 AM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 01:19 PM |
| bolt pattern is 5x100? | derka-derka | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-30-2012 03:58 AM |
| Bolt Pattern, Wheel Hubs and Studs | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 03-08-2012 03:49 AM |
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 07:04 PM |
