Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Traction control activating in 3rd and 4th gear...
Hey guys, I seem to be having an issue with my 2017 BRZ, which has crept up yesterday and persists today.
On the highway, in 3rd and 4th year, at above 3/4 throttle to WOT, traction control seems to be activating (with the light flashing rapidly on the dash) as I am accelerating, limiting power. I should note that the car is completely stock save for a catback, and I do have adequate grip in these situation. I did have winters swapped onto the car for the first time as of this past weekend, so I'm not sure if the smaller wheels (BBS 16's on 205/55r16 WinterContact Si's) are causing issues, or if the tire shop potentially messed something up with a wheel sensor. If anyone has any tips they can share, that would be awesome.
Drives: 2013 Hot Lava FRS
I don't have any technical knowledge on this subject, but tell all your friends that your car breaks loose in 3rd and 4th
#3 | |
Good Job Subaru!
Drives: 2017 manual BRZ
Guessing the different size combined with soft compound is just too much for TC to handle. Just drive in track/sport mode
![]() Sent from my Pixel XL using Tapatalk |
#5 | |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
A.K.A. Starlord
Drives: 2015 Series.Blue
I ran that tire size for two years in the winter. I never had that specific issue, but it was easy to freak out the Ctability Control by just wiggling the wheel back and forth ever so slightly. Winter tires are soft, and winter tires combined with the taller 205/55 sidewall meant that the tires deflected so much before the car actually began to turn, that the Stability Control would step in thinking the car had actually lost grip and was understeering. I even have an old video of it:
[ame="https://www.youtube.com/watch?v=w1vDOxXH9Pw"]Winter Tires = Confused Car - YouTube[/ame] Having said that, I never remember having any issues while simply accelerating, unless the rear tires had actually broken loose. You did change all FOUR tires over, and not just the fronts or rears, right? Are you sure they are properly inflated? If all that is correct, I would think either an alignment issue, or indeed a damaged sensor during install...
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| Traction control | PolishFrs13 | Issues | Warranty | Recalls / TSB | 14 | 12-30-2014 02:31 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 01:56 PM |
| Why does my BRZ have LESS traction with traction control on??? | BRZnut | BRZ First-Gen (2012+) — General Topics | 19 | 12-16-2013 04:28 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
