Old 11-11-2017, 09:24 AM   #1
wasabiseaweed
Drives: 2017 BRZ Performance Package
Valenti 4th Brake Light wiring for 2017 MY
I recently hooked up my 4th brake light but was a little confused when I went through to try and wire it. Every tutorial I’ve seen talks about tapping into a blue wire, though there isn’t a blue wire in the wiring harness for the brakes...
It could be because my car is a 2017, though I’m not sure.
Anyone have an idea as to which color wire I should wire my 4th brake light into?
wasabiseaweed is offline   Reply With Quote
Old 11-11-2017, 03:56 PM   #2
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Which model did you buy specifically?
Is it an actual valenti or just valenti style (GCS etc.)? It might change the advice I can give as I'm not 100% sure if the wiring is the same.
I recently did this to my 2017 with a GCS smoked brake light. This is the guide I used http://blog.86speed.com/wp-content/u...ar-install.pdf
This is the best guide I found, but it is still a bit confusing.
The kit includes an extra set of wires (blue and black) that you need to harvest the blue wire from (or black, but for sake of clarity to match the guide using blue). You want to tap one end of this extra blue wire onto the blue wire of the new main harness that came with the light, and tap the other end into the brake wire of your tail light (green wire).
From the new main harness, black goes to the ground screw, and tap the end of the new brown wire to the red wire on your tail light.
You can easily test all of these before tapping by placing them into the ends of the tail light connector.
Hope that helps, I unfortunately did not have my phone with me to take pictures of my installation.
wolffbite is offline   Reply With Quote
4th brake light, brake, light, valenti, wiring
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
Valenti 4th Brake Light Wiring Heavyax Cosmetic Modification (Interior/Exterior/Lighting) 3 06-11-2017 08:39 AM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 07:51 PM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 12:57 PM
