Drives: Blue Man FRS
2017 diff swap
Has anyone attempted to swap out their stock differential with the new 2017 rear diff? I've been thinking about doing this to mines due to the more aggressive gear ratio,but i'm not sure if the new diff has different dimensions that would cause some sort of issues. If you've tried this or have some insight, comment below. Thanks guys!
You don't need to swap the whole diff. There are final gears available that you use with your current one.
http://www.ft86club.com/forums/showthread.php?t=66866
#3 | |
pessimistic skeptic
You want more power. So the right solution is getting more power. I recommend one of the followings. - header + tune - forced induction If I had the 2017, I would go back to 2016 final drive and upgrade with FI again. |
Final drive is a great way to go. It's a great analogue upgrade that is simple and effective as is the trans gear upgrade they did in the 2017's. The combination should net noticeable results. The 2017's have 4.33 gears now I believe. Not everyone needs to go FI. What is your goal with the car?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete Last edited by stevesnj; 11-14-2017 at 10:16 AM. |
#5 | |
pessimistic skeptic
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#7 | ||
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Note: the 2017 only went from 4.10 to 4.30, and only on the manual cars. This small of a change is very, very subtle. I went all the way to 4.56 and I sometimes wish I had gone to 4.88 on my manual daily driven car. I personally would not think the change to 4.30 is worth the expense. Gas milage takes a very small hit. With AC off, level freeway driving I still get 32 US MPG. Overall I average 26 mixed city/highway. Engine turns faster, but benefits from mechanical advantage - e.g. it may actually be under less stress.
pessimistic skeptic
You assert that final drive swap is "great: without giving any reason. Then ask "what is your goal?" as if you care. What is "great"? How is "great"? How does that greatness fit to the "goals" you asked?
We are discussing a technical topic, I would expect a little more logic and reason in the discussion. |
Drives: 2017 BRZ
An extra ~165 rpm at 80mph in 6th is negligible. Top speed is drag limited, so the gears will actually help in that department.
#10 |
Drives: frs
Watch "BRZ 4.1 to 4.88 Final Drive Thoughts" on YouTube
I'd really want to do the swap but on my opinion price keep me away |
#11 | ||
If you can do the labor the parts and oil are $600. The only tricky part is gear setup - and that is about $300 at a reputable shop. If you need full service (e.g. can not swap the differential yourself) that is another $300. All in should be about $1200 and one day.
#12 | |
Best way to go is get a used diff carrier from an IS300, you can find some with an LSD already, or get a "fun" differential :p, by the gears and swap it at your own leisure taking your time with the shims. At least, this is what I did and it worked out great. I'm using the MFactory Mechanical LSD, had the innards WPC treated, fine tuned the preload and lock capacity and after the 3rd oil change I hardly have any chatter. That might be a little far from what you want to do, but DAMN is it fun! Just my 2 cents. |
#13 |
pessimistic skeptic
Top speed is determined by the combination of power, drag, and gear ratio. Since drag is proportional to square of speed and power is a function of rpm, obviously, power will be balanced with drag force at a certain speed. If that limiting speed balancing power and drag is below the theoretical speed determined by the gear ratio and engine specs, the top speed will be limited by drag. Do you have the numbers and equations to back up your claim for our cars? It will not be as easy as saying 3000x4.1/4.33 -3000 ~ 165 rpm.
#14 |
Drives: '15 BRZ RA
Even with a 4.88 swap the difference is not that much. You have faster acceleration in same gear, but you have to shift sooner and the longer final drive ratio catch up..
Here is a comparison: [ame="https://www.youtube.com/watch?v=9X_jYLtoCMg"]BRZ 4.1 vs 4.88 Final Drive Comparison - YouTube[/ame] |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Lexus is300 diff swap M98 3.91 | ogrowup | Engine, Exhaust, Transmission | 5 | 02-28-2017 11:45 AM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 03:59 PM |
| RR Diff swap | Triumphrider | Engine, Exhaust, Transmission | 25 | 10-21-2014 09:34 PM |
| Diff swap help | wootwoot | Engine, Exhaust, Transmission | 30 | 06-10-2013 12:05 PM |
