Old 11-25-2017, 01:33 PM   #1
Pearl_Brz
Pearl_Brz's Avatar
Drives: 2013 Brz
P0018/Slip Light AND Cannot reflash.
Ok let’s start by saying I have read EVERY thread involving P0018/Slip Light.
I have my suspicions, just looking for extra ideas.
So this is my girlfriends car.
2013 Frs Auto with 89,xxxkm.
It has a Borla catback and a stage 1 map. (Been like this for 10,000km)
Now last week she got P0018/Slip Light with reduced power.
(Oil was above the bottom line, but is almost due for a change.
Running Motul 5w30)
I reset the code and it came back.
So last night I figured I would flash back to stock.
No luck. Ecuflash would immediately abort.
Tried over and over with no luck.
I even reflashed my Brz to make sure my computer/software/tactrix we’re functioning properly.
My suspicion is that the Ecu is glitching or has failed.
Any ideas?
-Sean
'13 Brz Drift Build - Junkyard 6.2 LS swap 396whp - CD009 Trans - R200 G35 3.5 diff and axles - Modded knuckles - FA500 Coilovers 10k/6k F/R - RIP FA20
'17 GT86 2JZ Build coming soon!!
Pearl_Brz is offline   Reply With Quote
Old 11-25-2017, 01:49 PM   #2
Pearl_Brz
Pearl_Brz's Avatar
Drives: 2013 Brz
Details that may or may not have anything to do with it;
-been running no front bumper, no inner fender on drivers side and no engine splash guard for a little over 3 months now.
-some nitwit ‘opened up’ her air box for more flow(stilll looking for a replacement)
-ecu was updated to a B01D Calid rom with the tune 10,000km ago
Old 11-25-2017, 04:17 PM   #3
steve99
post up the event log from ecuflash
The ecu has not failed or car wont start.
flashing to stock is unlikely to help with P0018
does ecuflash read the vin and cvn data?
a lot of 2013 cars has suspect obd ports. try putting forwards or backwards pressure on the tactrix then try to READ ecu.
I would not try write till you solve connection problems.
or try extension cable or bending the rows of pins inwards slightly on tactrix
Old 11-30-2017, 11:59 PM   #4
Pearl_Brz
Pearl_Brz's Avatar
Drives: 2013 Brz
Solved the connection issue, and flashed back to stock.
Code came back.
I still think ecu.
Old 12-02-2017, 06:18 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you tried logging or checking the Cam Position Sensor at all? Lets face it, you should check the symptom of the fault before assuming the ECU has failed.
.: Stealth 86 :.
Kodename 47 DJ:
ecu, frs, p0018, reflash, slip light
ABS and Slip Light illxkoncept Issues | Warranty | Recalls / TSB 27 07-10-2017 04:46 PM
CEL and Slip Light DTC P0353 rocketbunny86 Issues | Warranty | Recalls / TSB 7 03-23-2016 08:38 PM
Engine light/ slip light and P0458 evo4g63 Issues | Warranty | Recalls / TSB 1 10-06-2015 03:06 AM
CEL and Slip Light Gums AUSTRALIA 10 01-15-2013 09:42 PM
CEL and slip light? Rob_g Issues | Warranty | Recalls / TSB 2 10-03-2012 05:57 PM
