Old 12-19-2017, 06:44 PM   #1
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
BRZ - Full Race EFR 7163 Turbo kit - Clean Install
BRZ. 6 Speed. EFR 7163 Turbo. Tuning.
We just finished a full write-up on a very nice BRZ turbo build that was completed at our shop recently. This was a very exciting project for the client with top-shelf parts, and we are happy that he is happy. Read on to see what parts we used, why we used them, and some small details that added up to a very clean install and overall result.
Full Story - http://www.circuitmotorsports-blog.c...ce-bw-efr.html
Circuit Motorsports is offline   Reply With Quote
Old 12-19-2017, 07:30 PM   #2
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Thanks for the writeup.
I Currently utilize the BW 6758 and i am interested in how the car feels with the larger turbocharger installed.
when does the car generate boost? i think it is around 2000-2500 rpm on my motor.
does the cars owner have any plans to push the boost up past 20psi?
i am interested to see what a 71 series turbo can do with one of these motors.
Surok is offline   Reply With Quote
Old 12-20-2017, 01:10 PM   #3
Circuit Motorsports
The boost control was a little wonky, because we had to run a softer wastegate to keep the boost threshold under 6 pounds for the fuel system. It spools up and was making 6 pounds around 3k rpm.
When we can run a stiffer WG, and get more aggressive with the boost control it should improve. Overall this turbo spools up quick though!
The next step for the owner is bigger injectors, fuel return, and turning up the boost with real boost control. Goal is to stay around 350hp, then build the motor in the future.
Old 12-20-2017, 01:35 PM   #4
Amputechture
Drives: 2014 BRZ
Fuel return for 350 WHP?
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Amputechture is offline   Reply With Quote
Old 12-20-2017, 02:22 PM   #5
Circuit Motorsports
350-ish hp is about the area where we have seen issues without a fuel return.
Old 12-20-2017, 07:27 PM   #6
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i have 450whp, no fuel return. just a dw 65c and E85 fuel.
Old 12-21-2017, 01:22 PM   #7
Amputechture
Drives: 2014 BRZ
That's asking for drivability issues imo.
Old 12-21-2017, 07:28 PM   #8
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
nah, it drives perfectly.
fully built engine, gearbox, driveshafts, twin plate clutch etc.
Old 12-22-2017, 02:09 PM   #9
Amputechture
Drives: 2014 BRZ
Not you, I was referencing a car with a return system that doesn't need it.
Old 12-22-2017, 02:36 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Nice work, how long was the process?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 12-22-2017, 05:07 PM   #11
Circuit Motorsports
Not really, it just allows the fuel to be returned to the tank. If setup and tuned for it, it would not be noticeable at all. Most factory turbo cars come with a return style system, like a WRX or STI. It allows much more fuel pressure to be run. We ran into an issue with a Vortech SC car on 93 octane that wouldn't make more than about 360whp because of fuel pressure issues due to the stock return-less system.
*Also, we should clarify, it is pressure dependent, so around 12-15psi is where you will see the issue, and on most kits we have tuned that's around 350hp.
The install took about 3-4 days to get finished, tuning is about days worth of work to get it perfect.
Old 01-04-2018, 01:39 AM   #12
Evil Rocky
Drives: FRS
Very nice write up!
Evil Rocky is offline   Reply With Quote
Old 01-04-2018, 04:10 AM   #13
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
What's a setup like that cost?
SkyeHack is offline   Reply With Quote
Old 01-04-2018, 11:51 AM   #14
Circuit Motorsports
Originally Posted by Evil Rocky View Post
Very nice write up!
Depends on the options and turbo you choose. The Full-Race kit is around $6k, then we can add things like the oil cooler, clutch, fueling upgrades, etc.
If you're interested in a setup like this feel free to call or message us and we would be happy to assist!
Full-Race Motorsports Turbo Kit Owners Thread and FAQ VerusEric Forced Induction 141 05-11-2019 10:27 AM
best turbo kit - currently Full Race? TEAM SCION Forced Induction 41 10-14-2016 09:41 PM
SilverSkyline210's Full Blown Turbo Kit Install SilverSkyline210 Forced Induction 22 06-15-2013 05:23 PM
Full Blown Turbo Kit Install This Weekend Gulf Breeze/Pcola/FWB King Tut Southeast 42 02-16-2013 04:24 PM
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! Pure Automotive Mid-Atlantic 61 01-30-2013 09:38 PM
