Old 12-27-2017, 10:20 PM   #1
darkbluemn
Drives: Brz
Is it OK to raise engine a little bit on passenger side using washers?
I had issue with header rubbing the skid plate. I raised the engine a little bit using high grade washers on passenger side to solve the problem. It's about 2-3 mm. Is there any problem with this DIY?
Thanks.
darkbluemn is offline   Reply With Quote
Old 12-27-2017, 10:26 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Probably be a better idea to clearance or space the skid plate.....and easier...
Old 12-27-2017, 10:28 PM   #3
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
You would be better off taking the skid plate and pounding the part that's rubbing with a hammer, and/or getting stiffer engine mounts. This was a known issue with Ace headers and there is a guide to fix it.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-27-2017, 10:29 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Use a dremel and cut that small section of the skid plate off
Dr. BRZ is offline   Reply With Quote
Old 12-27-2017, 10:31 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Yes. Your DIY gave me cancer.* Why fuck up the geometry of the drive line to address an interference problem with an aftermarket part?
Tweak the skid plate, not the rest of the car.
*It's probably fine.
Old 12-27-2017, 10:53 PM   #6
humfrz
Thanks.
Hello darkbluemn and welcome to our forum .......
Welp, there went your warranty ......
(jest ah messen wich ya)
I checked with Bubba and he just rolled his eyes and mumbled something about that's what crowbars are for ......
humfrz
Old 12-28-2017, 01:06 AM   #7
FRS Justin
Drives: 2013 Asphalt FRS
or just buy a set of good motor mounts that don't flex
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-28-2017, 04:21 AM   #8
NRXRaptor
If I am able to install whiteline kits KTD 922, 925, and 926, would I be able to install engine mounts as well? I had to use almost all my consternation to do it but I did it
NRXRaptor is offline   Reply With Quote
Old 12-28-2017, 06:02 AM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
bash your header. It's an old time fix and doesn't effect power output at all.
Old 12-28-2017, 08:25 AM   #10
Grady
Grady's Avatar
This is the right answer!
Old 12-28-2017, 01:40 PM   #11
gtengr
Drives: 2017 BRZ
It was an easy job while changing out the header. Leaving the header in place makes it more challenging. I used the sti mounts and think they're perfect for a street car.
gtengr is offline   Reply With Quote
Old 12-28-2017, 02:16 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
2-3 mm of washers and you fixed your problem? An elegant solution.
Old 12-28-2017, 02:28 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just LOL'd at my desk.
I LIKE TIRES!
Old 12-28-2017, 04:06 PM   #14
Ultramaroon
not playing cards
If I let go of my obsessive emotional attachments, it really is.
WTB: 1 OEM STI Side Skirt (passenger side) x1UP Want-To-Buy Requests 4 09-12-2017 01:54 PM
WTB: passenger side amber side marker NJ-JDM Want-To-Buy Requests 4 05-18-2016 06:37 PM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 09:56 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 05:53 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
