Old 01-04-2018, 01:49 AM   #1
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Rear lower control arm endlink/shocks ratio adjustments
Hi all,
Just wondering if anyone uses the extra holes (left, center, right) in their adjustable rear lower control arms to tune stiffness for the rear suspension/sway bars.
Tried looking for information on how much stiffer or softer can we expect when switching to different configurations, not much info on these. Hopefully, some can share their experiences on these.
Brzerker is offline   Reply With Quote
Old 01-04-2018, 03:06 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Aren't those different mount-holes more meant for rather different lowering/drop, then for suspension stiffness tuning? As in if one wishes for extreme drop to relocate lower mountpoint aswell, to keep some of coilovers travel, in similar fashion like special upper mounts do? Leave stiffness tuning to rollbars & coilovers themselves, no?
Old 01-04-2018, 09:13 PM   #3
wparsons
wparsons's Avatar
^^ Those specific holes pointed to by the arrow are to adjust the motion ratio for the sway bar, which would effectively tune the stiffness a bit. The holes are beside each other, not above or below.
Now, the shock mounting point has two rows of three, one above the other, that could be used to gain bump travel.
As for how much stiffer or softer, it's just math based on how much further in/out the extra holes are. It's not going to be a drastic difference though.
flickr
Old 01-04-2018, 11:36 PM   #4
Brzerker
Brzerker's Avatar
Do you happen to have any references on calculating the stiffness in regards to the extra holes?
I would be trying it out to get a butt feel but some numbers would be nice.
Old 01-04-2018, 11:51 PM   #5
Racecomp Engineering
You'll have to measure the change in the motion ratio (which would increases as you move the mounting point out towards the wheel).
Wheel rate = spring rate * motion ratio^2
Same for the sway bar. There are estimates of the spring rate of the swaybars floating around somewhere on here.
- Andrew
Old 01-05-2018, 01:05 AM   #6
jamal
jamal's Avatar
Drives: Legacy GT
The extra swaybar holes can be useful if you don't have an adjustable bar and want to make the rear softer or stiffer. Farther out should make it a touch stiffer.
Having a lower hole on the shock mount is also handy if the car is low because it'll give you back some much needed bump travel.
But all those other extra ones for the strut i would probably not ever want to use.
jamal is offline   Reply With Quote
FS: OEM Rear Beam Brace and Rear Lower Control Arms zeal86 Brakes, Suspension, Chassis 9 08-23-2016 10:05 PM
Rear lower control arm dim theGonz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-19-2015 01:44 PM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 11:17 PM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 05:40 AM
