Old 01-12-2018, 08:07 PM   #1
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
Subaru OEM STI Pinks - Springs (USDM/North America)
OEM STI Pinks will be available for the USDM market for 2017-2018 BRZ's, but they are not designed to be used on BRZ Limited with Performance Package or the BRZ tS.
Subaru BRZ STI Performance Springs
Part Number: B2010CA000
STI springs are stiffer than stock springs and lower the vehicle's ride height by about 10mm. The lower center of gravity can reduce body roll and result in improved handling.
Originally Posted by Veloist View Post
Turns out these are most likely not compatible with the Sachs dampers of both the PP and tS. The ‘18 BRZ catalog states they are not applicable to these cars.
Veloist is offline   Reply With Quote
Old 01-12-2018, 08:10 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Ouch @ $399.
Trueweltall is offline   Reply With Quote
Old 01-12-2018, 08:34 PM   #3
strat61caster
strat61caster's Avatar
Originally Posted by Trueweltall View Post
Ouch @ $399.
price will come down when supply > demand, $340 here
https://www.oempartstoyou.com/oem-pa...-mt-b2010ca000
ineedyourdiddly
Old 01-12-2018, 08:52 PM   #4
airjonny
airjonny's Avatar
Drives: Nissan Murano
[ame="https://www.youtube.com/watch?v=1A9NPrOYH4c"]OH MY GOD vine! - YouTube[/ame]
airjonny is offline   Reply With Quote
Old 01-13-2018, 03:55 PM   #5
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Don't the JDM STI springs have a 15mm or 16mm drop? These US market springs may be different if they are stating a 10mm drop.
TachyonBomb is offline   Reply With Quote
Old 01-13-2018, 07:44 PM   #6
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
If I want to lower my tS a little lower, should I get the JDM STI springs that have a higher mm drop? Would it off balance the suspension geometry? I am trying to fix the fist size gap the US STI springs come with.
SkyeHack is offline   Reply With Quote
Old 01-13-2018, 07:45 PM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If you're in Japan, why would you even bother trying to get USDM parts..??
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-13-2018, 08:41 PM   #8
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
I'm stationed in Japan bro. I''l be back to the states very soon.
Old 01-13-2018, 09:17 PM   #9
venturaII
venturaII's Avatar
That's nice, but it still doesn't answer my question.
Old 01-14-2018, 02:29 AM   #10
spike021
spike021's Avatar
Curious how well these would pair with the 2017 performance package Sachs dampers. I thought someone said the new tS or an older JDM version used the same Sachs. But maybe I'm wrong.
spike021 is offline   Reply With Quote
Old 01-14-2018, 04:09 AM   #11
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
The US tS comes stock with the US STI springs. I don't mind getting the JDM STI springs for my US tS. I am just wondering if its a lower drop and if it will throw off the balance of the US tS?
Do I make sense now?
Old 01-14-2018, 04:42 AM   #12
spike021
spike021's Avatar
I think @SkyeHack means he's getting the USDM tS but is wondering if he should pick up the JDM Pinks before he leaves Japan since they have a greater drop than the USDM springs. But he doesn't know if that'll throw off the tune for the USDM suspension.
Old 01-14-2018, 09:55 AM   #13
venturaII
venturaII's Avatar
It's not going to 'throw off the tune' or 'off balance the suspension geometry' any more than it would if installing JDM STi on any other version. In fact, there will probably be even less difference, and less reason to do so.
Old 01-14-2018, 10:43 AM   #14
Vital
Drives: 2015 BRZ
Im curious to see how well they pair up with the Showa dampers... I wish they lowered 15mm like the JDM STI Pink springs
Vital is offline   Reply With Quote
STI Pinks vs BRZ TS Springs blues15dp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 65 04-13-2023 12:51 PM
STI Pinks Springs ZC6BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 11-22-2022 09:33 PM
WTB: RCE or STI Pinks Springs Mr.Impreza Canada Classifieds 0 02-14-2016 01:11 PM
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 01:23 AM
86s headed for the North America? ksin86 BRZ Photos, Videos, Wallpapers, Gallery Forum 0 05-16-2012 07:10 AM
