Old 02-27-2018, 11:09 PM   #1
Butterballz
Drives: Black FRS
Bilstein B6 + Tarmac Springs + Raceseng Cascam
Hello ya'll,
So this was the setup I was going to run but noticed that there is a small gap between the Raceseng spring perch with the Tarmac springs. It's enough so that the spring can spin when the shocks are fully extended.
Has anyone ran this setup but with Bilstein B8 shocks? Is the shorter extended length enough to keep the springs captive compared to the B6?
This is quite a pickle I ran into. Wish I knew this before buying the B6.
Thanks!
Update for all those looking at this thread in the future
Bilstein B6 will not work with Tarmac springs, and Raceseng Cascam. You should purchase the B8 set instead as the shorter extended length will keep the springs captive when full droop.
Last edited by Butterballz; 02-28-2018 at 10:19 PM. Reason: Updated to inform so people that want to run this setup does not make the same mistake I did
Butterballz is offline   Reply With Quote
Old 02-27-2018, 11:15 PM   #2
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Originally Posted by Butterballz View Post
Hello ya'll,
Thanks!
Have you tried more preload?
idkwhatimdoing is offline   Reply With Quote
Old 02-27-2018, 11:20 PM   #3
Butterballz
Drives: Black FRS
Unfortunately that's not possible. The Raceseng spring perch bushing stops higher than the spring perch. So imagine without springs, the spring perch goes on the shock, then the perch bushing, but there is a gap between the bottom of the bushing with the top of the spring perch. The bushing can't go any lower.
Old 02-27-2018, 11:24 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@Racecomp Engineering could help I imagine. They are great to talk to on the phone so maybe give them a call tomorrow if you don't have an answer yet.
Old 02-27-2018, 11:45 PM   #5
idkwhatimdoing
Ah I gotcha. That’s interesting.. theres the spring perch hole and the bushing should be flanged, where the bottom portion of it fits into the spring perch hole. Not quite sure how the Bilsteins work, I have Ohlins. In my past there have been spacers I somehow forgot to install, maybe send pics?
Old 02-28-2018, 12:07 AM   #6
Butterballz
Drives: Black FRS
Mad gap.
Old 02-28-2018, 12:22 AM   #7
Butterballz
Drives: Black FRS
Originally Posted by Qadthane View Post
I paired RCE Tarmac springs with Raceseng camber plates. The lowering spring combined with the reduced stack height of the camber plate left the spring not captive when at full droop. The B8 damper, with its reduced droop travel, held the spring captive. If you think you may add camber plates later, going with B8's now may be wise. I'm not saying the B8 is better; I'm just putting info out there in case it is helpful.
Originally Posted by Racecomp Engineering View Post
It's a great set-up with a lot of happy people running that combo.
This would be the reason to get B8's, otherwise stick with B6. You may want the camber plates if you go to 245s.
We do have a our Bilstein/GTWORX coilovers coming out this spring...little bit firmer springs (but great valving) and a little more expensive than the strut + spring combo.
- Andrew
Just saw this in another thread. Looks like I'll need to get a set of B8's.
Old 02-28-2018, 12:30 PM   #8
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
Just out of curiosity, would you be able to tell me how much extra clearance the cascams would add between spring perch and tire in the front? I like the idea of coilovers but this car being my daily, and living in the North East, I'm trying to avoid something that will get destroyed by the salt on our roads, and something that needs to be rebuilt every few years
Sent from my ONE A2005 using Tapatalk
NyX_Nick is offline   Reply With Quote
Old 02-28-2018, 12:38 PM   #9
idkwhatimdoing
Mad gap.
Your springs have nicer paint than my car..
That’s very odd how that happens, based on what I can see is happening, maybe try adding some rubber spring perches above and below the spring (like the ones that sit on top of the stock springs on the stock struts) in an effort to raise the spring height, thusly raising the mounting position of the spring perch? I’m sure Raceseng knows what they’re doing, Jarrett is a very helpful and will attend to your concerns... I’d recommend contacting him through the company’s main email.
Old 02-28-2018, 02:37 PM   #10
Did you ever try using the Raceseng plates with the OEM upper spring perch?
The Raceseng spring perch is great, but our RCE springs were designed around the OEM parts which is why this issue exists.
But yes the Bilstein B8s would solve the problem.
- Andrew
Old 02-28-2018, 02:47 PM   #11
jamal
jamal's Avatar
Drives: Legacy GT
That looks like play between the strut shoulder, spring perch, and top mount.
So, remove the spring for a second, and stack everything on the strut the way it's supposed to go, snug the top bolt down. Is there any play or movement with the bearing, adapter, and spring perch? If so you need an extra spacer or something in there.
jamal is offline   Reply With Quote
Old 02-28-2018, 10:12 PM   #12
Butterballz
Drives: Black FRS
Sorry couldn't tell you. Never had these installed.
- Andrew
I have not but I really like the Raceseng spring perch so I'm going with B8's. Luckily Bilstein shocks seem to be out of stock everywhere so I was able to cancel my order I made in January except the one that shipped .
There will be play since the adapter rests on a ledge on the shock rod thing so it's unable to go lower. The spring perch will always be lower than the spring perch because of it and with the shorter spring, it creates a gap.
Old 03-01-2018, 12:13 AM   #13
wheelhaus
wheelhaus's Avatar
I had the Raceseng plates with RCE yellows on OEM shocks and everything fit perfectly. The B6's appear to need a longer spring to apply preload to the spring perch?
FYI if they haven't changed the design in recent years, the spring perches may bind against the bottom of the camber plate or the protruding screw shanks near full lock if you're dialed back for additional caster.
wheelhaus is offline   Reply With Quote
Old 03-01-2018, 12:40 AM   #14
Butterballz
Drives: Black FRS
Were you using the Raceseng spring perch or the OEM. Also, did yours have the longer bolts like in the thread below? Mine are shorter so I hope I don't run into any issues.
http://www.ft86club.com/forums/showthread.php?p=2392139
I'll put this info here in case it pops in someones search later and can be helpful. The decreased stack height of Raceseng cascam plates when combined with stock dampers leaves more space than RCE Yellows fill when the dampers are uncompressed. There is roughly 1/8 of an inch of play when the suspension is unloaded; enough that the spring can easily be rotated all the way around leaving it in an incorrect position on the lower spring perch when the car is lowered off the jack. I went over everything again last night to make sure there were no issues with my installation causing this. Everything was correct.
tl;dr Raceseng cascam plates on stock dampers with RCE yellows leaves slop in the spring when the suspension is hanging.
Also saw this post in another thread. Seems like he had issues with spring on staying captive with the same setup as you had.
Bilstein B8|RCE Tarmac Springs|Racer-X LCA|More H1C Brakes, Suspension, Chassis 3 02-19-2018 01:05 AM
RCE Tarmac springs w/ Bilstein B8 struts drifter-s Brakes, Suspension, Chassis 2 05-31-2017 11:50 AM
FS: RCE Tarmac 2 coilovers w/ Raceseng Cascam front plates TallTerror13 Brakes, Suspension, Chassis 4 12-27-2015 03:35 PM
FS: Bilstein B14 PSS Coilovers with Raceseng CasCam Plates dmarkey Brakes, Suspension, Chassis 2 06-02-2015 05:44 PM
Switched from RCE Yellows to Bilstein B8/RCE Tarmac Springs was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 01-24-2015 12:19 AM
