Drives: '17 PP BRZ
Best size lowering springs for a daily/drift car?
I recently got some 18x8 squared Raijins and it's too high so I was looking to drop it a bit. What would be the best size springs to keep the car functional on the road while also being good for drifting? I know coils are best but I just don't see me needed them at the moment. I've had my eye on the Eibach Pros.
Also, is there anything else that anybody would recommend that I absolutely upgrade when drifting an 86? Mainly stuff that has a tendency to break. I'm still pretty new so I'm thrashing it a little bit Edit: I do have the '17 PP with SACHS dampers Last edited by texastwurkt3am; 03-10-2018 at 02:13 AM. |
[insert cool phrase here]
Drives: BRZ Premium
Drifting you say?
All you need is practice and tires. After enough of that any nut can do that. Stuff only brakes when you hit stuff. So make sure not to hit stuff like curbs or walls. I recommend you don't be _____ and keep it off public roads. Go to race tracks. Worse case you snap an axle. Loweing spring wise, Eibachs (aka TRD) are perfectly fine for that compromise.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: '17 PP BRZ
There's an old abandoned NFL stadium parking lot that I've been using to practice when it rains. I'm down to be a jackass but not when it puts others at risk. Thanks for the advice!
Human
Drives: 2015 BRZ Black
Haha lol, i might have to join you one of these times.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Drives: '17 PP BRZ
LMGTFY
Drives: 13 FRS, 91 Miata
Clutch/shift fork.
When the clutch finally lets go. Most of the other stuff should hold up ok unless you hit something. |
| Tags |
| drift, lowering springs |
| FRS slow daily/ drift build | SciOnDrifTtSlIdeR | Member's Car Journals | 7 | 04-19-2015 02:50 AM |
| Lowering Springs and Wheel Spacers... Size?? | cjhopkins | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 03-14-2014 01:16 PM |
| Springs for a Daily Driver: Looks over Performance HELP ! | ScionFR-S | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-31-2014 07:55 AM |
| Lowering as a daily & sometimes spirited driver | 1086 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 12-24-2013 11:26 PM |
| Risky Devil BRZ - Daily / Drift car | ill roller | Member's Car Journals | 32 | 12-11-2012 09:26 PM |
