Old 03-10-2018, 01:51 PM   #1
Cal3000
Drives: Panda FR-S
Engine Chirping Noise and Exhaust Smoke
So when I was leaving work last night, I started my car and noticed a loud chirp knock like noise coming from the engine bay. I also noticed lots and lots of exhaust smoke coming from the pipes.
I was afraid it was a piston ring.
When I would rev the engine, the chirp would go away and the smoke would slightly subside. It seems like only at low RPMs or idle is when I would see smoke.
I drove home and make it home fine and the low rpm chirping was gone with no white smoke.
Started the car up this morning and everything seemed fine with only cold start up exhaust and no engine noise. Took it down the street and reved hard a few times and nothing.
Parked my car and let it idle and there was a faint chirping noise, not as loud as yesterday.
I check my exhaust and I see white powder, probably charcoal
could a canister purge cause white smoke?
If a piston ring was worn, would I just be a continuous sound?
I'm not sure about a head gasket issue as my car wasn't overheating.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 03-10-2018, 02:00 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Time for a compression and leakdown test
Old 03-10-2018, 02:05 PM   #3
My take on it from the little we know:
The chirping is the fuel pump. Probably the most documented noise a car ever made.
What is in the tail pipe looks like dirty water that splashed up in there.
That many solids were not created by combustion. Notice they do not extend past the weld in the tip?
Did it rain there recently? Damp air will cause white "smoke" at idle. It isn't smoke but steam from the moist air going through the combustion process.
Old 03-10-2018, 02:15 PM   #4
Cal3000
Drives: Panda FR-S
I notice that the fuel pump chirping came and went from time to time. This was the loudest I've ever heard the chirping/pinging and didn't seem normal. It was dry and mild yesterday so I don't think it was the steam.
Regarding the dust I initially thought it was dirt, however I noticed it was deeper down in the exhaust also and has the smell of charcoal.
What's weird was when I was driving home yesterday, the engine was running smooth.
Old 03-10-2018, 02:25 PM   #5
No CEL?
Did you fuel up recently? Maybe bad gas.
Old 03-10-2018, 02:33 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Crickets sleep until engine heats up. I'll guess belt squeal across labouring alternator pulley.
meh
Old 03-10-2018, 04:01 PM   #7
humfrz
Oh, I'd suggest that you just clean up the tail pipe then see if that residue returns.
Maybe the car will right itself ......
humfrz
Old 03-11-2018, 06:41 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
that looks like the material the catalytic converters are made of.
Are you tuned, do you have cats and what mods have you done?
Old 03-11-2018, 01:15 PM   #9
Cal3000
Drives: Panda FR-S
No CEL?
No CEL. I'm running 78% ethanol, I don't know how bad this gas can get. lol
Old 03-11-2018, 01:18 PM   #10
Cal3000
Drives: Panda FR-S
Yeah. I have a votech with just the header cat. The dust deposits smell like charcoal though. I shouldn't have too much carbon buildup since i've been exclusively using e85 unless carbon deposits can still be caught in the charcoal canister.
Old 03-11-2018, 01:46 PM   #11
Lantanafrs2
Drives: 2013 frs red
Chirping could have been clogged cat or pieces of it being rifled through the exhaust. Best case scenario is that you are now catless.
Old 03-11-2018, 01:52 PM   #12
That is pretty critical info. What other mods?
Old 03-11-2018, 03:26 PM   #13
Ultramaroon
not playing cards
Shit. We missed his sig. I guess now I understand why my link to the manuals is worthless.
OP, if cat is slutted it will sound different. Is it any louder now? P0420 code is probably disabled in your tune so burning a tank of premium won't help you check.
Old 03-11-2018, 09:26 PM   #14
Cal3000
Drives: Panda FR-S
Hey Guys
So it was the cat. I started up the car a few minutes ago and a bunch of material started chunking itself from the exhaust.
Thanks guys.
Looks like i'll have to get a new one welded on. I guess my next question is if all cats are the same? Are there some more restrictive than others? I don't want to weld on a cat that restricts too much exhaust flow.
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 10:41 AM
So chirping noise from high pressure fuel pump Nefarious Issues | Warranty | Recalls / TSB 19 03-12-2017 11:49 PM
Engine idle chirping (cricket) noise poll. Hanzo BRZ First-Gen (2012+) — General Topics 229 02-16-2016 02:21 PM
Chirping noise from the Rear Deck/Trunk shadoken Issues | Warranty | Recalls / TSB 22 11-23-2015 03:19 PM
