Old 04-11-2018, 11:11 PM   #1
Bent42
Bent42's Avatar
Different trans issue re:shifter centering
I've searched pretty extensively and have found all the normal trans issues, change the fluid, change the centering springs posts and haven't found anything related to my current issue. This is my second FRS and the first (used with 4500 miles on it) was stock and I did a trans fluid change and it improved shift performance significantly and shifted very well.
I recently picked up another with 24000 miles and it shifts horribly. It hangs between gears and won't go into the next gear sometimes. The shifter doesn't spring back to center consistently. I did a fluid change which improved smoothness but did not solve the centering issue. I installed Mtec centering springs and saw little improvement, I even changed the shifter (an IRP which I love) but it still doesn't center consistently.
Has anyone experienced this condition?
Bent42 is offline   Reply With Quote
Old 04-12-2018, 01:39 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Sounds like the PO bent something in the rear housing. Did you buy it sight un... driven?
Perrin Shifter Bushing / Trans Mount Support (SOLD) Apex_BRZ Transmission and Driveline 1 02-24-2017 06:03 PM
Photo Request-Top of trans where shifter connects continuecrushing Engine, Exhaust, Transmission 0 04-07-2016 04:49 PM
Auto Trans issue Triumphrider Issues | Warranty | Recalls / TSB 9 11-04-2014 08:34 PM
Manual Trans (Reverse Issue) mxrcmxlendon Engine, Exhaust, Transmission 1 02-25-2014 12:18 AM
Brand New - Perrin Shifter Bushing and Trans Support Philly758 Engine, Exhaust, Bolt-Ons 3 06-30-2013 04:09 PM
