Old 04-17-2018, 11:01 PM   #1
Kushkaki
Kushkaki's Avatar
Drives: Sold 16 FRS, 22 Neptune 86 on order
Removing Condensation from Valenti tails?
Hello, I’ve been looking around for a fix for condensation in Valenti tails. I’ve found a few old threads but all the responses talk about how to PREVENT future condensation; I need to get rid of the condensation. Any and all help would be very appreciated
Kushkaki is offline   Reply With Quote
Old 04-17-2018, 11:38 PM   #2
humfrz
How about heating them up with a hair dryer ......
humfrz
Old 04-18-2018, 12:03 AM   #3
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
throw it in the oven
Jesse36m3 is offline   Reply With Quote
Old 04-18-2018, 09:03 PM   #4
OfficeWorker
Drives: 2018 WRX STI
How much condensation are we talking about? Smaller silica gel packs can be very useful for removing smaller quantities of condensation - but obviously the caveat is that silica gel can only absorb a certain quantity of water before the pellets become saturated and need to be either recharged or replaced.
OfficeWorker is offline   Reply With Quote
Old 04-30-2018, 04:11 AM   #5
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
I was told by a friend not to tighten up the bolts too much on the valenti's. Because it'll cause gasket to get squished into too much thus condensation can seep in. Just my two cents!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 04-30-2018, 09:44 AM   #6
Drill a small hole in an inconspicuous section on the top of the taillight. Heat the light with a blow dryer so the moisture is forced out. Fill the hole with a little dab of silicone caulking. If more shows up peal the caulking off the hole and repeat.
Old 08-31-2018, 04:22 PM   #7
LotsaMiles
Drives: Scion FR-s, xB, iA, Silverado Z71 4
I still have factory tail lights on my 2013. In my case I just loosened the turn signal light. Fixed it in no time. I just leave it loosened now. No water buildup.
LotsaMiles is offline   Reply With Quote
Old 09-06-2018, 03:50 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Gasket ninja for a permanent fix seems to be the case
Old 09-06-2018, 03:56 PM   #9
DrButtDrugs
yerp
Drives: 2015 WRX
I drilled a tiny hole (1/32) at the lowest point of the housing of each of my stock taillights which both had water pooling. Didn't bother sealing the holes after. Now my tails are always bone dry. YMMV.
DrButtDrugs is offline   Reply With Quote
Old 11-26-2018, 07:29 PM   #10
Kushkaki
Kushkaki's Avatar
Kind of resurrecting this thread because 7 months later aaaand my lights condensates again. Pretty bad this time (it’s always my left light that gets condensates, right is perfectly fine). There was a good pool of water in there, shook as much as I could out then threw them in the oven for a bit. Now there’s just some droplets on the face of the light. I’ll try the drilling method someone mentioned, and will definitely be getting gasket ninja soon.
Old 11-26-2018, 07:55 PM   #11
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I don't see how this is an issue. Doesn't rice naturally absorb moisture?
Old 11-26-2018, 08:28 PM   #12
Kushkaki
Kushkaki's Avatar
Lol thanks for the laugh.
Old 11-28-2018, 08:20 PM   #13
Decep
Drives: 2013 FR-S Series 10
At minimum get new gaskets from the dealer or dealer websites.
Old 11-29-2018, 12:29 PM   #14
RallySTI
Drives: 2013 Subaru BRZ
Whenever I get some condensation in my tail lights I just set them on one of the heat ducts and they are dried out by morning.
RallySTI is offline   Reply With Quote
FS: Valenti RED Tails. Valenti RED 3rd Brake Light. OEM Clear Corners. AngryS13 Exterior Parts (Aero, Lighting, Etc.) 6 08-14-2016 12:35 PM
Condensation in Tom's Tails ericmpena Issues | Warranty | Recalls / TSB 2 10-28-2015 01:58 AM
OEM tails, no condensation! jarednoel Exterior Parts (Aero, Lighting, Etc.) 1 01-31-2015 04:33 AM
Condensation in TOMs tails? SLICVIC Cosmetic Modification (Interior/Exterior/Lighting) 26 11-05-2014 11:39 AM
Aftermarket tails, condensation? CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 41 02-14-2014 10:32 AM
