Old 07-26-2012, 03:25 AM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
swapping out stock Lugs
my car came with XXR 530 (i believe) 18 in wheels, and i want to swap out my lugs for some blue ones. would they be the same specs as for the stock wheels?
also, if so, what would be a good alternative to these just due to the cost? (quality is a must!!)
http://www.shopgreddy.com/accessorie...ug-nuts-4.html
lbroskee is offline   Reply With Quote
Old 07-26-2012, 04:19 AM   #2
Caliban
Terrorist of Chat Rooms
Drives: 05 E46M3, 06 CT9ARS, FR-S?
XXR wheels use different type of lugs. you should double check the taper ends of current lugs. Are they ball-joint style or tuner style (60 degree)??
As far as I know, GReddy lugs and many other such as Project Kics, Muteki, Rays, ADVAN and MXP lugs are in 60 degree taper-end.
Caliban is offline   Reply With Quote
Old 07-26-2012, 04:36 AM   #3
D1cker
Drives: B9 S4/ND2
I just ordered the GReddy lugs for my car. Evasive has a huge selection of different lugs if you want to try something cheaper.
http://www.evasivemotorsports.com/mm...tegory_Code=L1
D1cker is offline   Reply With Quote
Old 07-26-2012, 11:21 AM   #4
lbroskee
lbroskee's Avatar
ok thanks for the info. i just decided to contact the dealer to be on the safe side
Swapping for clear side markers ayau DIY (Do-It-Yourself) Guides 62 06-01-2016 02:49 AM
Swapping the stock nav system. yeabude Electronics | Audio | NAV | Infotainment 24 01-28-2013 06:12 PM
Swapping out the Amber Bulbs for Chrome Ones. BR33Z3 DIY (Do-It-Yourself) Guides 21 08-30-2012 04:30 PM
Do dealers re-torque lugs during PDI? Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 05-08-2012 11:54 PM
