Drives: scion frs
CEL,traction control and ABS sensor light up after I broke my Abs speed sensor?
so last night I was changing my rear driver wheel bearing assembly and forgot to remove the abs speed sensor(in short I broke it) I know for sure to get the ABS sensor light on because of that so my question is
* why my Check engine light and traction control alsi light up? * and if I just replace a new Abs speed sensor, will it be resolve the issue? * what to do after replacing the broken abs sensor? - I never touch anything other than the rear driver wheel (rotor,break pads,hub assembly, etc) |
Well, first off ..
that's fer not payen attention and busten the wheel speed sensor.![]() Secondly, I'd suggest you just replace the wheel speed sensor and see if that "fixes" everything. After that, if you still get a code, clear it and see if it comes back. You may have to disconnect the battery for a spell to clear the code. humfrz |
#3 | |
It will also be in "limp mode" so your cruise will not work and your revs will be restricted. Just replace the sensor and all will be good. Like said you will probably have to unhook the battery for a reset. This will make the car seem to run strange until it relearns.
#4 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
Replacing the ABS sensor should resolve the issue. You shouldn't need to do anything other than drive the car for a bit after replacing it. Worst case, you might need to clear the codes (if you don't have a scan tool, just disconnect the battery for a minute.)
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
Drives: scion frs
[QUOTE=humfrz;3102623]Well, first off ..
that's fer not payen attention and busten the wheel speed sensor.![]() Secondly, I'd suggest you just replace the wheel speed sensor and see if that "fixes" everything. After that, if you still get a code, clear it and see if it comes back. You may have to disconnect the battery for a spell to clear the code. lol totally forgot that so I definitely desever the slap haha thanks for the input, gonna call the dealership to get a new one. btw is it still okay to drive the car casually?.with just a limited speed? |
#6 | |
Drives: scion frs
#7 | |
Drives: scion frs
A.K.A. Starlord
Sure. Nothing will explode. Your ABS, and other driver aids will not be functional, so keep that in mind. Drive cautiously until you have it fixed.
You might consider pulling one of the ABS fuses in the meantime to fully disable it. I've seen weird stuff happen as a result of damaged sensors (ABS coming on when it wasn't supposed to, which significantly increased stopping distance, for example.)
#9 | |
[quote=kuyumoy;3102693]
![]() Back in the day, when we had only a single cylinder braking system and we pushed the brake pedal to the floor .. and it just stayed there, we learned how to rev match/downshift and pull on the emergency brake … all at the same time, as you looked for a soft spot in the ditch. (that outta convince you to keep er off the road) humfrz |
#10 |
Drives: hyper blue
ABS is for chicks.
#11 |
#12 |
Drives: hyper blue
Yes, you pump and modulate the brakes. A wise person drives below the limits of adhesion.
My last house had a steep 1/4 mile long driveway. When it snowed, I would pull the ABS fused to pile snow in front of the tires to stop. With the ABS engaged, you could either stay below the 3mph threshold or pitch the car sideways to stop. If the ABs engaged, your speed would pretty much double but it was a 20% grade in the steepest part. Not a fan. |
#13 | |
However, for 99% of us, I believe ABS is quite beneficial. ![]() humfrz |
#14 |
Drives: FRS 2013
Normal for traction light to come on, I can explain in detail but basically the traction system is "ABS" while driving. Ex, if your car detects slip it will brake certain wheel(s) to maintain control with traction control on.
Not sure why CEL is on buy most likely related. Replace wheel speed sensor and car should be fine to go right away. |
| Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? | Anthonyc77 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-19-2018 09:57 PM |
| So i broke my wheel speed sensor | bkblitzed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 11-18-2016 05:04 PM |
| Broke Oxygen Sensor during Header Replacement - Can i run w/o one? | Adeel | Engine, Exhaust, Transmission | 7 | 05-20-2014 03:12 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 09:11 PM |
