Drives: 2016 subaru brz insta@black.xira
gauge issue
soo all sudden my gauge dash stop working i replace the 7.5 fuse and it blows try 10 it blows,try a 15 and it blows idk what the issue is but i need it cause i cant use my turn signal and the alternator not charging battery
Drives: Subaru BRZ
My bet is on the alternator, probably has a short internally and is causing the problem.
soo removing the connections on the alternator and retrying the fuses again would eliminate the shortage ?
Drives: Subaru BRZ
Yeah that's what I would try, if it doesnt blow the fuse you know you have a failed alternator
Whatever it is, I wouldn't keep putting bigger fuses in the slot …. or you will find the problem, when something starts smoking...
![]() Like suggested, you may wish to check the alternator. https://www.aa1car.com/library/battery_runs_down.htm Then, I would look for a short … what is the last electrical thing you did with the car?? humfrz |
the alternator is disconnected the fuses keeps blowing . i have a volt meter install and it reads 11.5 when car is running last electrical thing i did was install car audio amp
#7 | |
Weight Weenie
Drives: 15 FR-S
The fuse blows because you're drawing too much current. Putting a larger one in is only going to damage something or cause a fire. Stop doing that... Chances are something went wrong with your install and you have a hot wire grounding out. That would be my first guess. Whatever you did, undo it, and see what happens. |
#8 | |
Yep, it sounds like you have a dead short in that circuit. Did you install the amp? If so, like suggested, you may wish to check your work. If someone else installed the amp, I'd suggest you take it back to them and ask them to sort it out. That ought to keep you busy tomorrow .. ![]() humfrz |
#9 | |
#10 |
Drives: Subaru BRZ
What fuse exactly is it that keeps popping?
#11 | |
humfrz |
#12 | |
I Love custom Turbo kits
Drives: Limited BRZ
#13 |
Drives: Subaru BRZ
Get a code reader and check for codes too, might be surprised and find something there
#14 |
Im already a step ahead remove the gauge cluster disconnected and put fuse in and still pop im try code reader
| Tags |
| brz |
| AEM Oil temperature gauge and pressure gauge with pods. | mtsound | Engine, Exhaust, Bolt-Ons | 2 | 08-24-2017 01:55 PM |
| Innovate MTX-A boost gauge issue (solved) | go_a_way1 | Electronics | Audio | NAV | Infotainment | 10 | 10-06-2016 08:08 PM |
| Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 01:48 PM |
| Gas Gauge Issue | Jruex22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-04-2013 11:28 PM |
| Ecutek gas gauge issue fixed | maj75 | Engine, Exhaust, Transmission | 1 | 03-23-2013 12:49 PM |
