Drives: 2017 PP BRZ HKS supercharged
Finding wheels to clear brembos
Build is a 17 brz with performance package, factory brembos all 4 four wheels, lowered 1 inch on feal 441 coilovers, and hks supercharged.
Looking for wheel recommendations 18x9.5 square setup that will clear the brembos. Is this even possible? I think the only ones I have seen are te37s but those are out of my price range. Looking to spend around 1500$. So far I have looked at enkei TS9 and TM7. After asking fitment industries, their rep said spec 18x9.5 +45 offset will not clear the brembos in the front, I would have to run 18x8.5. I do not want to run staggered. Curios if there are even many other wheels that will fit my desired specs. I have had trouble finding alot of information on brembo wheel clearance on the forums. Please send pictures of any builds you know with similar specs, and links to the wheels. Thanks in advance, Joseph |
My 17x8 +43 Enkei RPF-1's clear, bigger shouldn't have a issue.
Just contact your local suppliers, they should have a big range of brands in different styles. |
Drives: 2018 BRZTs,
I think the volk 57cr will clear in that size you are looking for, I would contact ft86speed factory.
Drives: it's grey
use google but clarify your search terms. this was one of the top results by seraching "ft86club brz performance package brembo wheel"
https://www.ft86club.com/forums/showthread.php?t=122138 |
Drives: 2019 BMW ///M4
Work Emotion Kiwami 18 X 9.5
I have Wilwood 6 Piston FR and 4 Piston Rear and there is tons of space between the caliper and rotor. A good 1 inch at least!
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Drives: it's grey
Wilwood are a far thinner caliper than a Brembo. Correlating their fitment to another caliper doesn't work.
#9 | |
#10 |
#11 |
I can help. PM me.
#12 |
N1rve
#13 |
Drives: 2014 Subaru Forester
Apex ARC-8 17x9 +42 fits over Brembos. ~17lbs, no hub rings required.
#14 | |
Drives: it's grey
Also, what are you looking for? The topic of this thread is very broad but you then reply "not looking to spend that much" and "I don't like that style". What price, specs, and spoke design do you seek. With that people can better help you. |
| Tags |
| bbk, brembo, brembo big brake kit, brembo brake |
| Do BRZ/FRS/GT86 wheels fit over rear Brembos? | Elliotw | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-13-2018 05:30 PM |
| Performance Package Brembos Freezing to Wheels? | texastwurkt3am | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-23-2018 09:31 AM |
| Will stock wheels clear Wilwood BBK? | Brody602 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 11:32 AM |
| Are the stock wheels clear-coated? | Tromatic | Northwest | 2 | 07-29-2013 10:47 AM |
| Are the stock wheels clear-coated? | Tromatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-18-2013 12:09 AM |
