Old 10-18-2018, 01:05 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
What have you guys done to relieve any vibrations inside your 86?
I'm researching all the potential vibration spots on the inside of my BRZ, it takes a beating on these terrible roads in Ottawa, Ontario (Yes, nation's capital can't afford to fix pot holes every 10m). What are some of the things you guys have done to eliminate any vibrations inside the car? Thank you in advance!
scottryan is offline   Reply With Quote
Old 10-18-2018, 01:45 PM   #2
Well almost anything you do involves some sort of trade off but there are options.
The big three:
Sound and vibration Matting - Will reduce noise but to do right is a pile of work and adds weight.
16" Wheels - Have a deeper sidewall to absorb bumps better but will reduce handling in the corners.
Softer struts or coilovers - Same effects both good and bad as 16" wheels.
Old 10-18-2018, 01:54 PM   #3
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I realized most of the vibrations I was hearing were in the plastic interior panels... so I just removed them. Free weight savings. Increased road noise from my tires coming through from underneath though, but eh, now I don't hear any vibrations.
Tristor is offline   Reply With Quote
Old 10-18-2018, 02:14 PM   #4
humfrz
You might consider different tires.
Reducing the tire pressure a few pounds usually helps.
humfrz
Old 10-18-2018, 04:25 PM   #5
scottryan
Financial Distress
scottryan's Avatar
humfrz
Should mention my car isn't running completely stock, I've got 18" rims with 255/35 tires, barely lowered. My coilovers are a bit stiff though so I'll look into fixing that
Old 10-18-2018, 04:35 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
https://www.parts-express.com/sonic-...12-4---268-046
add a layer directly on top of the metal in the inside of your car, then put everything back on top of it
Old 10-18-2018, 04:37 PM   #7
StraightOuttaCanadaEh
Wes
1. Reducing tire pressure - sometimes even 1 psi will make an appreciable difference in noise and comfort
2. Bushings - surprisingly fitting rear subframe bushings from Whiteline made the ride more pliant and less crashy. The clunks went away as well. I gained a bit of noise but the good kind. In fact, after fitting all the trans/diff/subframe bushings and inserts, friends say the car sounds like it was tuned. But it's less clunky.
3. Knowing what causes them - sometimes it's your work ID badge in the door pocket that keeps rattling. Sometimes the passenger seat isn't fully clicked into position. Sometimes it's the seat belt buckle against the door. The rear seat back being clicked into position on only one side drove me crazy for months til I figured out that's what it was.
Other than that, no rattles really.
Instagram: @gt86ws
Old 10-18-2018, 04:37 PM   #8
humfrz
and you're blaming the ROADS -
humfrz
Old 10-18-2018, 04:38 PM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
If it's the vibration from the road, the only thing you can really do to affect that is the damping of the suspension, stiffness of the shock, and the tire that you're running on.
For me, I am running Tein Flex A (the one with hydraulic bump stop) at 15 clicks so it's super soft. The springs I believe are 6k, but anything about 6k is pretty stiff. Tune your suspension for max softness. For the tires, what is going to matter is the sidewall stiffness and tire pressure. You want a more passenger-like tire, I'm running Michelin Pilot Sport 4S @ 35 PSI and it's a little stiffer than I would like, but if I drop it below 35 PSI my MPG takes a 1-2 MPG hit if not more. You may want to try to drop your PSI to 32.
I'm currently trying to find a comfortable and quiet tire in 255/35 R18 However, most tires in that size are performance tires.
N1rve
Old 10-18-2018, 05:27 PM   #10
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
install loud ass exhaust so you don't hear vibrations anymore. lol. jk.. idk i kinda just deal with mine and enjoy my BOV noises.
pgranberg11 is offline   Reply With Quote
Old 10-18-2018, 05:32 PM   #11
18" rims are like running tires made of rubber bands. Not the best for rough roads.
Old 10-18-2018, 06:01 PM   #12
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
get a louder exhaust, install a sub and empty your care cup
HKz is offline   Reply With Quote
Old 10-18-2018, 06:21 PM   #13
ST185RC
Drives: White Out FR-S
Living on the west side of Vancouver, I have my fair share of potholes around my house. Ironic, how houses in my area are all around $2M-$5M a pop, yet we have such shitty patchy roads. In contrast, east Vancouver has much nicer roads, repaved, but houses are averaging around $1M.
Anyways, I find it's much worse in the winter. I also find that a clean interior helps with NVH especially when you wipe stuff down with 303 aerospace wipes or armorall. the tradeoff is residue.
Oh, turning off the vibrator in the passenger seat also helps.
ST185RC is offline   Reply With Quote
Old 10-18-2018, 07:32 PM   #14
scottryan
Financial Distress
scottryan's Avatar
It's got a catted Magnaflow exhaust, the vibrations are loud from coming from inside the cockpit, probably the 3rd brake light vibrating against the rear window?
Highway vibrations??? Fred Flintstone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-09-2018 11:33 AM
Guys only ! Have a laugh or two inside.. Mikem53 Off-Topic Lounge [WARNING: NO POLITICS] 29 10-23-2014 12:07 PM
Transmission Vibrations Scavanger Engine, Exhaust, Transmission 2 09-22-2014 03:09 PM
Anyone having problems with vibrations? ShibaYuki CANADA 22 01-21-2014 10:06 PM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 04:07 PM
