Old 10-21-2018, 09:50 PM   #1
Xerexyz
Drives: 2017 Toyota 860 in Supernova
Fitting 5.25" speakers in the rear
Had anyone tried to modify the rear brackets to fit a larger speaker? 3.5" is a pretty depressing variety of speaker.
Xerexyz is offline   Reply With Quote
Old 10-22-2018, 02:28 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes.
Better question why?
Want more bass add a subwoofer. No other way to get around it.
Either shallow mount small all-in-one unit. Or a big ass duel 12" in ported box.
But go on and try it. You'll all come to the conclusion that you need a subwoofer.
Old 10-22-2018, 07:40 AM   #3
Kerrija
Drives: 2016 Subaru BRZ Limited
Oh I understand his reasons, there are more variety of speakers in the larger size.
Kerrija is offline   Reply With Quote
Old 10-22-2018, 02:43 PM   #4
MJones_RB
MJones_RB's Avatar
You're going to have to create a custom mount, either wood or MDF. If you access to a 3D printer, even better. Plenty of room in there to fit the speaker, just as long as the magnet isn't super-big. Be sure to line the metal area around it with some Dynamat (or even that spray-on rubber stuff works) to reduce vibrations.
MJones_RB is offline   Reply With Quote
Old 10-22-2018, 03:46 PM   #5
cjd
cjd's Avatar
Drives: 2017 BRZ
No good reason to keep speakers in the sides unless you build boxes... They probably add some midrange fill, and it won't really what you put in there (without containment) - you'll only get midrange because there's just no managing the pressure off the back.
As noted, plenty of space. Little value.
Old 10-23-2018, 02:00 AM   #6
Xerexyz
I do have a 3D printer. I'll have to look up the depth there.
I have some pretty nice coaxial speakers I'd like to use there.
Old 10-23-2018, 09:20 AM   #7
Chimera
Drives: FRS
There was a post on here from someone who made a 6.5 bracket for the rear,and posted the files. Probably could find it fairly quickly by searching 3d print and speaker. Idk that that will help though as you'd need to modify it to be 5.25
Old 10-23-2018, 10:30 AM   #8
Xerexyz
You were totally right he's the thread
I'll update them for 5.25 and make a post with a link to the file.
TWO 6-1/2" SPEAKERS INSIDE REAR SEATS GTR STYLE mmontes Electronics | Audio | NAV | Infotainment 19 03-06-2020 01:47 PM
Has anyone tried to replace the rear speakers with a sub and/or larger speakers? soilent Electronics | Audio | NAV | Infotainment 9 12-28-2017 04:48 PM
Rear 4" speakers question Adam_L Cosmetic Modification (Interior/Exterior/Lighting) 3 10-30-2016 04:27 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 07:31 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 12:08 PM
