Old 07-29-2012, 11:08 PM   #1
JW89225
Drives: E92
HID Plug 'n Play Kit
Just got my headlights retrofit with my plug-n-play HID 6000K. Install was pretty straight forward and clean, no messy wiring under the hood. It comes with a slim ballast.
Stock on left, 6000K on the right.
Let me know if anyone is interested, i believe the kits are around $75.
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
Old 07-29-2012, 11:18 PM   #2
encity5
encity5's Avatar
This was with morimotos retrofit kit from the retrofit source ?
encity5 is offline   Reply With Quote
Old 07-29-2012, 11:19 PM   #3
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Take note everyone, last picture tells you everything you need to know about PnP kits.
*Insert sigh here*
This and blacked out tails are going to be a plague for this car, I can feel it already.
MmmHamSandwich is offline   Reply With Quote
Old 07-29-2012, 11:20 PM   #4
MmmHamSandwich
Drives: '13 FR-S
Hell no. That cutoff is turds. The TRS kit is a legitimate retrofit with projector swap. This is just a bulb swap, not a true retrofit.
Old 07-29-2012, 11:22 PM   #5
encity5
encity5's Avatar
Which is why I was confused with "retrofit plug n play"
Old 07-29-2012, 11:31 PM   #6
MmmHamSandwich
Drives: '13 FR-S
Yeah, you have your terminology correct. While the morimoto kit may not be plug n play, it is a direct bolt in. If I get an FR-S instead of a BRZ I'll be buying the TRS kit no questions. The intro price would have been nice, but a standard retro will cost you $300 in labor alone and the install won't be as clean as a direct bolt in. I'm stoked for Scion owners to have the option.
Old 07-30-2012, 12:17 AM   #7
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Halogen Projectors with HID 4300K Kit, squirrel finders bent down hard
TRS Morimoto's with 4300K Kit
The difference is dramatic, no glare,
and the high beams are amazing, high beams on below
After aiming the retrofitsource kit the difference really stood out on a very dark straight 2 lane road, the road was clearly lit up and yet the opposing lane was dark, you can actually see the cut off line for the opposing lane. My apologies for the poor quality pictures.
tonystewart is offline   Reply With Quote
Old 07-30-2012, 12:25 AM   #8
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Not retrofit, cheap ghetto drop in kit. Mod can change title.
Khyron686 is offline   Reply With Quote
Old 07-30-2012, 12:53 AM   #9
Style
LXXXVI
Style's Avatar
Drives: Dahlia (Raven FR-S)
why is there soooo much hate towards PnP HID kits?
Style is offline   Reply With Quote
Old 07-30-2012, 12:59 AM   #10
KO7
Drives: VW GTI
Because the glare blinds oncoming people. Do it right with retrofits or don't do it at all.
KO7 is offline   Reply With Quote
Old 07-30-2012, 01:02 AM   #11
styl3z
styl3z's Avatar
Drives: 2013 Scion FRS Whiteout
Sorry, I'm a noob when it comes to HIDs, but won't the retrofit blind oncoming as well since HIDs are brighter no matter if its PnP or retrofitted?
styl3z is offline   Reply With Quote
Old 07-30-2012, 01:03 AM   #12
RidetheTran
Drives: Toyota
you beat me too it, I dont get why this is such a hard concept to grasp...lets take a moment of silence for those that are currently being blinded by pnp kits
RidetheTran is offline   Reply With Quote
Old 07-30-2012, 01:04 AM   #13
RidetheTran
Drives: Toyota
If you look at the first pic by OP, you can see the glare above the cut off line. In a real retrofit, there wouldn't be this glare that goes in the drivers faces. The retrofit gives the light a clean cut off.
If you ever drive behind a car that comes with stock HID's, yes it'll be brighter than cars that don't come with projectors. But hell, it's not as bad as driving behind someone with projectors running HID's, you'll feel like you're staring straight into a flashlight.
Old 07-30-2012, 01:32 AM   #14
Style
LXXXVI
Style's Avatar
So the glare is what is hitting the floor in OPs first pic right? Other than that, they only real difference that I see is the color. What about this squirrel mod that people are doing? Doesn't that fix the problem?
BRZ -> FRS Climate Controls Retrofit? kndonlee Cosmetic Modification (Interior/Exterior/Lighting) 21 05-26-2015 03:34 AM
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 08:37 PM
HID Retrofit Kit install Jidonsu NY / NJ / CT / PA 1 08-04-2012 02:24 AM
Need Expert on Retrofit !! Ericfrs Cosmetic Modification (Interior/Exterior/Lighting) 3 07-22-2012 01:22 PM
Retrofit heated seats to Premium? blalor BRZ First-Gen (2012+) — General Topics 4 05-31-2012 08:50 AM
