Old 02-22-2019, 11:31 AM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Registry Thread: Failure After J02 Recall
Proposing we leave an entry here for reference. This is not an argument thread about whether or not you should have participated in a voluntary recall, this is to document that your failure occured using a simple template. Please refrain from calling out your specific dealership. So far, spun rod bearings seem to be the most prevalent catastrophic engine failure.
Vehicle Mileage:
Vehicle Make:
Mileage After Recall Performed:
Symptom(s):
Failure:
State:
Is Dealership Offering Repair:
A discussion thread had been opened here - https://www.ft86club.com/forums/show....php?p=3192939 Please feel free to vent and discuss your experience so far in this thread.
TheDrive has posted an article as well, you can find it here - http://www.thedrive.com/news/26848/s...-their-engines
Jalopnik has also posted an article, you can find it here - https://jalopnik.com/scion-fr-s-and-...ast-1833220101
https://tinyurl.com/y2hy5kx4 This is a spreadsheet created by @tanner - simplified view of failures that have occured
Old 02-22-2019, 11:40 AM   #2
kopecma
Spun #3 rod bearing
Mileage: 45000
Vehicle make: Scion
Mileage after J02 recall: 80
State: Mo
Dealership offering repair: Toyota replaced short block as part of goodwill powertrain warranty (vehicle in warranty by mileage but out by dates by 5 months) customer stuck with labor to install new short block.
kopecma is offline   Reply With Quote
Old 02-22-2019, 12:47 PM   #3
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Oil starved entire crank area, main and rod bearings scored, crank seized
Vehicle Mileage: ~71000
Vehicle Make: Scion
Mileage After Recall Performed: 4xx
Symptom(s): Cruising down the highway, sudden lurch from the engine, clutched in and pulled over immediately, engine does not turn over after
Failure: all Main and Rod bearings
State: PA
Dealership Offering Repair: Under investigation
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 02-22-2019, 01:52 PM   #4
DarkPira7e
DarkPira7e's Avatar
Vehicle Mileage: 53,610
Vehicle Make: Scion
Mileage After Recall Performed: 413
Symptom(s): Sudden onset of ticking that turned into heavy engine knocking within seconds.
Failure: Rod bearing
State: Vermont
Dealership Offering Repair: after 31 emails and 54 phone calls, they have agreed suddenly to repair my engine. Parts have 12mo warranty. Dealership said I'll get the invoice for all parts replaced when everything is done.
Old 02-22-2019, 05:48 PM   #5
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
Vehicle Mileage:
130,918 as of 19 Feb 2019
Vehicle Make:
FR-S
130,634 as of 12 Feb 2019
Symptom(s):
Ticking, knocking, grinding, low performance.
Failure:
#4 Cylinder Rod Bearing Spun.
State:
California
Toyota of Santa Cruz says this isn't the result of the Service Recall that was performed.
Quoted $7.5k for used engine w/ 1-year warranty or $8.5k for new short block.
UPDATE: 03/04/2019
Dealership says tech found the ecu codes were recently deleted when they took the car from me. I told them I don't know what's going on. They say, based on that, they are not paying. I'm screwed.
Last edited by Magoo; 03-04-2019 at 05:16 PM. Reason: Updated info from Dealership.
Magoo is offline   Reply With Quote
Old 02-22-2019, 05:56 PM   #6
CT86
wannabe S2k owner
Drives: '13 Raven FR-S
Vehicle Mileage: 80000km
Vehicle Make: Scion
Mileage After Recall Performed: <120km
Symptom(s): Brief high pitched sound on cold starts
Failure: Knocking and power loss, engine shut off on the road
State:ON
Dealership Offering Repair: under investigation
CT86 is offline   Reply With Quote
Old 02-22-2019, 09:37 PM   #7
venenon
Drives: 2013 FRS , 2002 MDX, ZZR600
I'm surprised and somewhat relieved to find that I'm not the only one.
I thought it was coincidence until I found this thread.
Vehicle Mileage: ~74000
Vehicle Make: 2013 Scion FR-S
Mileage After Recall Performed: ~500
Symptom(s): Knocking/Clacking noises and stall
Failure: Not determined
State: OR
Dealership Offering Repair: Dealer offered to source another short block
venenon is offline   Reply With Quote
Old 02-23-2019, 09:55 PM   #8
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Originally Posted by mswbrz View Post
I see only frs / Toyota cars as having issues after recall
This might give some credence to the concerns that some owners voiced over having Toyota techs work on boxer engines that they are not very familiar with vs. Subaru techs who work on boxers every day. Unfortunately, it isn’t as if the Scion owners have the choice to go to a Subaru dealer for this recall.
NCtoBRZ is offline   Reply With Quote
Old 02-24-2019, 12:23 AM   #9
GrantedTaken
This does not bode well for my existing mistrust
http://www.ft86club.com/forums/showp...&postcount=854
GrantedTaken is offline   Reply With Quote
Old 02-24-2019, 12:25 AM   #10
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
This is now, officially, my least favorite thread ever. As one who had the recall done about 250 miles ago, I am now, officially, scared out of my mind. Thanks for nothing...
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 02-24-2019, 12:30 AM   #11
maslin
Benz Tech
Drives: 2017 BRZ Premium
It would be very difficult for a dealership to be crooked. If someone is ripping you (or more likely the warranty department) off it’s the tech. Make something up, pretend it’s fixed, get paid for the work and no one ever knows.
Hard to fake taking an engine out. I don’t think anyone would be dumb enough to fake a federal recall.
Techs work on cars for a living. Some (actually very few) push the limits. No one wants to get fired. If you get fired you don’t get paid at all.
maslin is offline   Reply With Quote
Old 02-24-2019, 01:12 AM   #12
D_Thissen
D_Thissen's Avatar
Which I find kind of amusing, since it's a Subaru engine.
Old 02-24-2019, 04:03 PM   #13
CT86
wannabe S2k owner
Originally Posted by D_Thissen View Post
Which dealership did the work?
DM'd you
Old 02-24-2019, 04:25 PM   #14
GrantedTaken
I'm convinced they won't even do the work. I'm going to ask the tech to take a photo of the head or engine removed and send it to me. I'll mark the cowl so I know the pic is from my car
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-19-2019 12:24 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 07:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 08:23 PM
