Old 02-23-2019, 06:15 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
P0172 CEL fixes
This is the third time i fixed my P0172 CEL. Wanted to list the fixes here for the others who might ask for a fix.
Symptoms were all same
- Engine service and traction control off light come up, OBDII reports P0172 (system too rich)
- MAF reading during warm idle is above 3.5
- Rough idle, reduced power, and an overall noisy engine. Especially after the catback, exhaust sound was drony and much louder than normal. Engine is hesitant to rev up.
Fixes
1- The first time fix required just cleaning and reseating the MAF sensor
2- Second time months later was much harder since I had to chase down leaking vacuum lines. The two vacuum lines under the intake manifold connecting to the solenoid, their both ends (i.e. four ends of two lines) needed to be clamped. All of them were completely loose.
3- I fixed this CEL third time yesterday for a completely different reason. Oil catch can was completely full and overflowing. That is PCV not crankcase; crankcase never collects any oil. Cleaning and resetting the CEL fixed the problem immediately.
Hope this helps someone ...
Edit: I have not seen any other CEL and hope this is the last time. But all of the causes were my error as the person servicing my own car.
Old 02-23-2019, 09:00 PM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
Did you mean P0172?
Thanks! Yes
Old 02-23-2019, 09:04 PM   #3
J1Avs
Drives: 2018 BRZ tS
Very helpful info! Thanks for sharing!
Are you still using the stock JRSC filter or did you swap to a dry filter? I’ve heard that helps with the MAF getting dirty?
J1Avs is offline   Reply With Quote
Old 02-23-2019, 09:10 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
Yes, i swapped to AEM Dry Flow. There is one model with the exact same size. I had posted the number in JRSC thread
Edit: AEM Dry Flow filter number is 21-2036DK
In case MAF sensor needs to be replaced, I also bought and used Denso 197-6160 sensor as a replacement which works and fits exactly same as the stock MAF sensor but sold for less than half price.
Old 06-05-2019, 11:03 PM   #5
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
mrg666,
I was wondering if you only ever received the P0172 code or if there were others? I recently received a P0172, C1201, C1241, and B14A1 and, from my research, I am suspicious that the bypass valve provided with the JRSC kit may be at fault, but I am also going to clean the MAF for good measure. I was just wondering if you've had any issues with the bypass valve related to a P0172 code?
Thanks.
vfrqqq is offline   Reply With Quote
Old 06-06-2019, 08:27 PM   #6
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by vfrqqq View Post
mrg666,
Thanks.
I have not seen P0172 because of bypass valve. P0172 means fuel mixture is too rich in other words not enough air. When the bypass valve is not working when the throttle is closed, it just stays closed and causes P0174, lean mixture (not rich) due to too much air at idle (and, of course, the risk of compressor surge). If bypass valve working okay, you should be able to hear the whistle of bypass valve opening with closed throttle. It is also useful to have an OBDII reader to check the MAF value. It should be stable around 2.8-3 at closed throttle and warm idle if MAF sensor is working right and bypass valve is opening.
If you have P0172, fluctuating rpm at idle, and hesitation before revving up, I would clean the MAF sensor first. If it doesn't help, i would check the leaks from air pipes and vacuum hoses.
Old 06-06-2019, 11:03 PM   #7
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Thanks for that. Just cleaned my MAF this afternoon, cleared my codes and, things seem to be working correctly again. I did check the evap hoses under the intake manifold and, while the are movable on their spigots, they had not come off to date and I've had the JRSC for about 1,200 miles or so. I'm still going to secure them for piece of mind, but haven't made it a high priority.
Also, I was thinking maybe it was the bypass valve because of this https://www.ft86club.com/forums/show...01#post3088309
Old 07-28-2020, 02:56 AM   #8
SPCorBUST
SPCorBUST's Avatar
Thought I'd contribute my experience to this post. I got the code a couple weeks ago, experiencing the rough idle, hesitation, and notably louder drone at speed. Cleaned the MAF, and the code has not come back since.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-28-2020, 09:21 AM   #9
mrg666
pessimistic skeptic
mrg666's Avatar
Another reason can be faulty MAF extension cable, if used.
Old 08-21-2021, 10:28 PM   #10
im.rocketeer
Drives: 2013 Toyota-86
Fixes
@mrg666 - Hi! Did you only clean the PCV valve?
im.rocketeer is offline   Reply With Quote
Old 10-09-2021, 03:25 AM   #11
SPCorBUST
SPCorBUST's Avatar
Have also seen this combo:
P0172
P1170
P117B
Found a helpful, related document: http://zatonevkredit.ru/repair_manua...KvrzlLPWuuGJnl
p0172, system too rich
Paint chip fixes kchkwan Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 46 04-04-2015 02:16 AM
Program that fixes CEL and disable DTL Chuck. Software Tuning 10 05-08-2014 11:00 AM
frs car accident fixes all_aboard Northern California 9 04-07-2014 11:23 PM
Crickets, RPM/idle, CEL/SL fixes Mr.EvoMR Issues | Warranty | Recalls / TSB 6 11-12-2013 09:44 AM
production line fixes? pr086 Scion FR-S / Toyota 86 GT86 General Forum 14 08-01-2012 01:07 PM
