Old 02-25-2019, 02:39 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Intake Cam Sprocket failure
Dropped my car for valve springs recall and was told that my intake cam sprocket was broken and had to be replaced.
Dealer told me Subaru would cover half of the portion, and dealer would take off the labor cost. However, I am still liable for some portion plus tax ($200ish)
Car is 68k miles 2013 brz. Is this common to have cam sprocket failure?
Is this something I can fight for it to have my portions waived?
Thanks
hanabie is offline   Reply With Quote
Old 02-25-2019, 07:29 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
http://www.ft86club.com/forums/showthread.php?t=15577
Appears it is not uncommon.
Gunman is offline   Reply With Quote
Old 02-25-2019, 07:53 PM   #3
ka-t_240
How did it break? Did it break during disassembly?
Codes or issues prior to recall work?
ka-t_240 is offline   Reply With Quote
Old 02-25-2019, 08:10 PM   #4
humfrz
Good questions.
I would wonder what was broke about it? Cracked? A tooth broke off? Other?
humfrz
Old 02-25-2019, 08:15 PM   #5
Gunman
Could be one of the cam sprockets that had issues from the beginning, and the valve spring recall work put it over the edge.
Old 02-25-2019, 08:46 PM   #6
BRZnut
Drives: BRZ DGM Limited
If your car was fine with no codes before you brought it in for the recall, then they broke it during the recall work and you should not have to pay for the repair!
First Drive - CEL - Cam Sprocket Fix TeamSweet86 Issues | Warranty | Recalls / TSB 113 09-30-2018 10:49 AM
Timing chain sprocket tooth broke Jamesallen45 Issues | Warranty | Recalls / TSB 9 08-28-2018 05:24 AM
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
FA20 Cam Sprocket Question pleong Engine, Exhaust, Transmission 4 01-24-2015 09:48 AM
