Drives: SWP BRZ
Rattle when i turn off the engine
I have a rattle every time i turn off the engine.
It feel like the exhaust system vibrate with the engine and rattle on the frame or whatever. A budy of mine who work for subaru for many years will look at it soon but for now i want to know if im the only one with that problem. Thanks ! |
Waited 5 years for this
Drives: '18 MX-5 Club
I've never heard of any noise when I turn off the engine. I would freak out too if mine makes a noise like that.
#3 | |
Drives: SWP BRZ
![]() I will try tonight to hold the shifter when shutting off the engine maybe its related to the shifter linkage anyway i will find a solution. thx Last edited by Subforever; 08-01-2012 at 04:20 PM. |
Drives: SWP BRZ
I tried to put my hand on the shifter but no luck i felt nothing and the ratlle was still there. It seem it is coming from the engine bay or maybe lower near the firewall
#5 | |
Pull my finger...
Drives: Silver Scion Slushbox
The exhaust components, especially the cats will crackle, pop or tick when cooling down. Easily mistaken for rattles or a problem if you've never heard metal contracting as it cools. Sometimes it can be really loud. This is completely normal in most cases.
Here's an extreme example. You'll hear a particularly loud one but if you listen closely, you'll note other less intense pops. They will range from louder to more softer ones. If you live in an area where it gets cold in the winter, and you have central air and heat, you'll hear your metal ducts within your home make similar noises when the heat turns off. [ame="http://www.youtube.com/watch?v=5NI-zR4YafY"]2011 Audi A4 Noise - YouTube[/ame] Quote:
DADA
Drives: 2013
I have the same rattle, I know what your talking about.. I assumed it was exhaust o.o
DADA
Drives: 2013
And it's no pop noise, it's an actual rattle.. You can definitely feel the car shake
#8 | |
Drives: SWP BRZ
![]() CircuitJerk: Its really a rattle not a crackling pop or whatever sound from sheet metal cooling down it only happen when the engine turn off, for a brief 2 second i hear toc toc toc from under the central console. I have an appointment in 2 weeks i will post the solution right after. Thanks guys |
Pull my finger...
Okay. I see. A little short on the details originally. Hard to tell on a forum.
All the best. |
#10 |
Drives: 2013 c63 & 2012 370z Sport/Navi
try stepping down ur clutch and turning off your engine. it may help.
#11 |
Drives: SWP BRZ
My car is at the dealer right now and the sound is coming from inside the fuel tank. Weird because at the beginning the sound was coming from the firewall then some days later from the back... Anyway they need to reschedule an appointment for further investigation.
i will let you know ! |
#12 |
Drives: 2015 AOZORA EDITION
Did you ever find out what it was ? I think I'm Startin to get this aswell and mines a 2015 model
| Flywheel Rattle? | CB762 | Issues | Warranty | Recalls / TSB | 119 | 11-16-2016 11:09 PM |
| Interior rattle | frsinpa | Issues | Warranty | Recalls / TSB | 132 | 03-23-2015 05:09 PM |
| Downshift rattle?? | driftartist | Issues | Warranty | Recalls / TSB | 17 | 08-03-2013 11:00 AM |
| A/C Rattle? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-17-2012 08:46 PM |
