Drives: Turbocharged 2015 Scion FR-S
Turbo Flutter
I recently purchased a Turbocharged 2015 Scion FR-S (Automatic).
It pulls smoothly when under full boost, but makes a fluttering noise (audible in the attached video). What is causing this noise or what should I try to narrow down the source? https://photos.app.goo.gl/3Nyjx5VS1s75xoeg9 Specs: - Full MaPerformance turbo kit - Delicious tuning flex fuel kit - Borla catback exhaust - Open dump wastegate - 350 wheel horsepower - 12 lbs of boost |
Drives: 2013 WRB BRZ
Sounds like wastegate flutter
Any idea on how to mitigate the flutter?
Assuming it is caused by the wastegate. |
Drives: 2014 BRZ Limited, Satin White Pearl
Frequency of the ebc needs to be tuned higher.
Rust bucket enthusiast
This is your EBCS frequency.
Drives: WRB BRZ
Just to clarify the statements already made about the EBCS frequency, this is not indicative of an issue with the car/setup. Whoever tuned the car can increase the wastegate frequency to turn the BWA-BWA-BWA-BWA sound into a BWAAAAAAA sound, but the only difference will be the sound. The car will otherwise drive and feel more or less the same, but adjusting the frequency is entirely preferential. If you want the wobble, keep it unchanged, if you want it smooth, increase it. A setting between 20 and 30 Hz would make it smooth.
Ahh yes, it pulls smoothly, I am just not a fan of the sound and would prefer it to be smooth.
For anyone curious I figured out what the source of the noise was.
The previous owner who installed the turbo kit routed the boost controller incorrectly. It no longer makes jackhammer noises! |
| Tags |
| automatic frs, flutter, maperformance, noise, turbo |
| Open Waste gate “Flutter” | Kris86 | Forced Induction | 3 | 05-13-2019 09:56 AM |
| Wastegate flutter!! | sid94 | Forced Induction | 14 | 08-19-2018 12:31 PM |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 03:41 PM |
| Hood flutter at high speed | TheseColorsDontRun | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 09-10-2013 11:39 AM |
