Old 08-02-2012, 05:24 AM   #1
Camotec
Large Member
Camotec's Avatar
Drives: Toyota GT86 - Silver
Question Enkei Raijin Matte Black Staggered
Hi Guys.
I am from Australia and I have been looking around the forums for a while and I am expecting my Silver 86 in October.
I want to get my wheels sorted now.
I am getting Enkei Raijin Matte Black in 18" and after looking at the forums I am thinking about the fitment below.
Fronts: 18x8 +45
Rears: 18x8 +35
I will be running 225/40/18 Michelin Pilot Sport 3 tyres.
I would like to know what you think? opinions? Should I not do this?. When running the same offset the front tends to stick out more so I thought that by running the +35 on the rears it will square it up.
I will be lowering on coilovers between 1-2 inches.
I look forward to hearing from you.
Cheers
Camo
Camotec is offline   Reply With Quote
Old 08-02-2012, 05:36 AM   #2
crimespree
Drives: 86
i am in the same position as you
i love the enkei raijin matt black but couldn't find the weights, have you?
for 10mm difference in offset i wouldn't bother, stops you rotating any wheels without taking tyres off, a little lowering will make it look great...
i see you are in sydney, pm 86drift, he will be able to look after you for enkei wheels, i am getting some through him
crimespree is offline   Reply With Quote
Old 08-02-2012, 05:57 AM   #3
Camotec
Large Member
Camotec's Avatar
18x8 +45 your looking at around 8.5kg a rim --- Still a lot lighter than a lot of rims out there
yeah I guess I am trying to go for the look which is why I wanted to put the rear out some more. I get I wouldn't be able to rotate but I dunno.....
I will still be using my 16's for trackdays etc. and plan on getting a decent set semis for them. so I might get cheaper low resistance tyres so I can afford replacing them more often
Old 08-02-2012, 06:33 AM   #4
BRAWL
Drives: Toyota 86 GTS Velocity Orange
20.3lbs per wheel according to tirerack.com
Not my cup of tea, but still pretty light for an 18x8 so even with the extra weight from the tyre (if any), it will more than be made up for with the extra width
BRAWL is offline   Reply With Quote
Old 08-02-2012, 07:23 AM   #5
crimespree
Drives: 86
came back to post 20.3 but LZ beat me to it...
won't be lowering my car for 2 reasons (1 is money) straight away, wonder if the matt black will look OK at std height
Old 08-02-2012, 08:58 AM   #6
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
should be a pretty good fit
dori. is offline   Reply With Quote
Old 08-02-2012, 01:32 PM   #7
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm going staggered offset also on the TSW Nurburgring, same sizes as yours. I think the 10mm is worth it to keep the rears from being so sunken.
JoeBoxer is offline   Reply With Quote
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 12:37 PM
enkei raijin 18x8 raven frs thebear21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-06-2012 04:03 PM
Going Matte Black DYI carbonBLUE Cosmetic Modification (Interior/Exterior/Lighting) 9 07-20-2012 04:51 PM
Enkei Matte Black RP03 Racing Series wheels! toxicdrift Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-22-2012 04:37 PM
