Old 06-20-2019, 10:20 PM   #1
Outlander
Outlander's Avatar
Drives: 2013 scion frs
Loud ticking post recall fix
I have a 2013 FRS automatic about 75000 miles. This is post recall fix about 1200 miles or so. I am hearing a loud ticking ever since the recall. Sounds like a card in bike spoke. It is not there all the time and it increase in speed as the car accelerates. I have been working with dealer that did recall. But currently they are saying it's the high pressure pump and that it can't be fixed. But this noise was not the before recall fix, and it does not sound like videos I have seen online of a chripping high pressure pump. They have flushed the lines and state they did find and remove some sealant. I don't know what to do next.
Outlander is offline   Reply With Quote
Old 06-20-2019, 10:21 PM   #2
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Video?
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 06-20-2019, 10:36 PM   #3
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Did they replace your serpentine belt? I had them replace the belt and spark plugs when the recall repair was done. After, I was having a noise like what you described. They said it was the fuel pump but I knew it wasn't the same sound the pump makes so I kept insisting and they offered to replace the fuel pump, after they replaced it the noise was still there, then they decided I had a bad clutch but they wanted me to pay this time, I told them the noise was there even when the clutch wasn't engaged so finally they had a "master tech" take a look to find that the new belt was defective, they replaced it and that fixed the problem.
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 06-20-2019, 11:02 PM   #4
radroach
Drives: car
Check that it isn't the vacuum pump issue on AT models. There was a post just yesterday about that issue.
Old 06-21-2019, 11:05 AM   #5
Ichima
Drives: 13' Lightning Red Brz
I'm having the same issue, I'm going in today to get it diagnosed for the 4-5 time. So I will post an update on this.
Ichima is offline   Reply With Quote
Old 06-21-2019, 10:32 PM   #6
Outlander
Outlander's Avatar
Thanks everyone for the replies. This would be my 5th trip back as well. I will try to post a video tonight, but it's hard to capture on audio over my invidia exhaust. Yes they did replace my serpentine belt and plugs.i don't know if my garage has a master tech. Btw did you record the audio problem you had to compare. I will check the vacuum pump post.
Old 06-22-2019, 04:36 PM   #7
Outlander
Outlander's Avatar
Here is an example of the clicking noise. Like I said it's hard to pick up but I have reduced the hum of the exhaust in an attempt to make it easier to hear. I have also included an example without the clicking so you can hear and compare.
Old 06-23-2019, 03:38 AM   #8
jflogerzi
jflogerzi's Avatar
Ouch that does sound weird. I would get someone to rev it while sitting stationary and pop the hood see if you can pin point which side is louder and front or back of engine bay... Might help pin point problem.
2013 Series 10 FRS #553
Old 06-24-2019, 01:12 AM   #9
Outlander
Outlander's Avatar
Ok, I will give that a try and repost thanks, for the suggestion.
Old 06-24-2019, 03:22 PM   #10
subaru
Drives: STI
Keep me posted. Same exact issue here. I figure if it doesn't blow up I will just trade it in some day. Sucks. Literally sounds identical post recall.
subaru is offline   Reply With Quote
Old 06-24-2019, 03:34 PM   #11
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
just curious but did you get your TOB replaced?
DandoX is offline   Reply With Quote
Old 06-24-2019, 04:06 PM   #12
Ichima
That doesn't sound good at all. TBH I had those same exact noises and they ended up finding sealant in my oil pickup and oil pan. This led to a spun rod bearing. Was a hell of a fight, took them 2 months to finally be put at fault by another dealership and also a Subaru of New England Rep. I'm having a new ticking noise that's a lot higher pitched and gets louder at higher RPM's. My ticking is very quiet at low RPM's and once I pass 3k RPM's it's more visibly noticeable.
Old 06-24-2019, 04:11 PM   #13
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Hard to tell, but it sounds a little bit like my issue.. the tech had adjusted the valves on my new engine too tight. Ask him where in the range he put them after the recall. Should be in the middle, and NOT to the tightest tolerances.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 06-24-2019, 06:00 PM   #14
sato
sato's Avatar
Drives: Dodge Patitas
I know our engines sound like lawnmower engines sometimes, but that seems loud af. Hope it is eventually diagnosed and fixed, and don't eventually blame it on your exhaust and some excuse like decreased back-pressure was the root cause.
Sent from my Pixel 2 using Tapatalk
noise, post recall, sealant, ticking
She lives once more! (post-recall damage) BlackOptics Northwest 9 03-22-2019 07:53 AM
Loud ticking from engine Norotor Issues | Warranty | Recalls / TSB 8 04-24-2018 02:45 AM
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 06:46 PM
alright my tenth post so i can officaly post in the marketplace destiny86 Scion FR-S / Toyota 86 GT86 General Forum 4 02-04-2016 01:49 PM
Engine is making a loud ticking with Redline 0w20 KevinBRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-29-2013 10:34 AM
