Old 07-31-2019, 09:03 PM   #1
conehead
Drives: RS 2.0
SSC setup thread
What alignment and suspension settings do you run? Post em up. There are no wrong answers, this is just a place to share what you like and what you have learned.
For reference, here are the initial settings Tire Rack recommends:
Suggested Baseline Settings After Alignment
  • Front Camber: -3.0 degrees (Confirm wheel and tire clearance near spring perch before driving, 3mm minimum clearance recommended.)
  • Front Caster: 5.4 degrees(left)/5.5 degrees (right)
  • Front Toe: Zero
  • Rear Camber: -2.25 degrees
  • Rear Toe: 1/8-inch total toe-in
  • Tire Pressures: 35 psi all around (baseline, tune to surface and driver)
  • Front and Rear Sway Bar: Set at outermost adjustment or softest setting
  • Front Shocks: 1.0 turns (of 2.5 turns total available)
  • Rear Shocks: 1.5 turns (of 2.5 total available)
conehead is offline   Reply With Quote
Old 08-03-2019, 10:32 PM   #2
Rigel
Drives: 2013 Scion FRS 10 series
I've liked my setup so far but I'm still learning.
Front Camber: -3.2 degrees
Front Caster: 6.25 degrees(left)/7.0 degrees (right)
Front Toe: Zero
Rear Camber: -2.5 degrees
Rear Toe: 1/64-inch total toe-out
Tire Pressures: 32 psi hot all around
Front and Rear Sway Bar: Front soft, rear hard
Rigel is offline   Reply With Quote
Old 08-22-2019, 08:26 AM   #3
steverife
Drives: 2016 Scion FRS
Tony R got in a lot of seat time early and shared this...
http://www.ft86club.com/forums/showp...postcount=1124
His experiences largely matched mine, though I never messed with hard/soft.
Running soft/hard gives me a car that I've been very happy with in sweepers and I can drive confidently in slaloms, but I find hard to consistently place in the offsetty sweepy in between stuff. At bumpy sites, the car can be really loose on throttle on exit. Cranking up rebound helps mitigate that.
Running hard/hard drastically improves all the weaknesses I find with the front bar on Soft, but it is really easy to lose the front of the car. I tend to struggle with asking too much of the front, so I've struggled trying to make front hard work all season.
Overall, I've found the setup extremely frustrating and will hopefully be debuting the car with a few simple STX mods the week after nationals.
steverife is offline   Reply With Quote
Old 08-22-2019, 08:02 PM   #4
conehead
Drives: RS 2.0
I just got everything together and aligned, using a combination of past experience and what I gathered around the interwebz:
Front camber: -3.3/-3.2 (max)
Front toe: 0
front sway: soft
front struts: stiff
rear camber: -2.3
rear toe: 0.15 degree in each side
rear sway: stiff
rear shocks: stiff
tires: 32/32
I have not had a chance to test yet, but will say that the car still rides and drives pretty well on the street with the shocks set to full soft. Other comments about a choppy ride and ground clearance issues have not been a problem for me. It is not as smooth as stock, but doesn't annoy me at all. I also have a Release Series with the front splitter and still haven't scraped. Steering feel is a little more vague on center, but the car doesn't tramline.
Old 08-22-2019, 08:35 PM   #5
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Dumb question, what's SSC?
timurrrr is offline   Reply With Quote
Old 08-22-2019, 09:18 PM   #6
conehead
Drives: RS 2.0
Solo Spec Coupe is an SCCA autocross and race class. It is just for the FRS/BRZ with specific suspension mods and tires.
Old 08-23-2019, 04:26 AM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Thanks, that explains why you were discussing settings as if you all had the same suspension model.
Old 10-19-2019, 08:55 PM   #8
conehead
Drives: RS 2.0
Finally got to try the car out last weekend. The recommended 32/32 tire pressure was WAY too high. I ended up dropping all the way down to 28/26 without any rollover issues and won the event.
Old 10-20-2019, 08:47 PM   #9
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I didn't think camber plates were allowed in SSC. Are you guys getting that much front camber with just camber bolts?
smg1138 is offline   Reply With Quote
Old 10-22-2019, 01:40 AM   #10
conehead
Drives: RS 2.0
Yep, most people who get less than that are not following the instructions properly on the bolts. Another guy in my local club claims 3.5 degrees.
Old 10-22-2019, 04:02 AM   #11
strat61caster
strat61caster's Avatar
The koni Yellows have an enlarged upper hole on both sides instead of the big hole small hole for the factory tapered bolt which is a big help to getting more camber.
Bit of a kerfuffle a few years back as this was illegal for Street class and Koni had to issue washers to limit the camber available from the bigger holes.
ineedyourdiddly
Old 02-06-2020, 06:25 PM   #12
conehead
Drives: RS 2.0
New tires coming soon to SSC
https://www.scca.com/articles/201342...ction-for-2020
Old 03-24-2020, 01:47 AM   #13
conehead
Drives: RS 2.0
New Falken RT660 approved for SSC next month. I'm sure these are faster tires, but I kind of liked having longer lasting rubber as the spec tire.
Old 03-29-2020, 05:59 PM   #14
conehead
Drives: RS 2.0
SSC should be doing well in PAX competition at the remaining events this year. We finally got a realistic PAX factor for 2020 with the current tires, and now have much faster tires available.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 07:36 AM
Official Roll Cage/Bar Thread **Show off your setup!** slava Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-02-2015 11:05 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring NY / NJ / CT / PA 0 10-20-2014 11:48 AM
